Timing Question
Old Jun 15, 2013 | 06:43 PM
Timing Question
I have a 70 Vista Cruiser with a 350 4bbl- all stock, which I bought about a year ago. I am just now getting it sorted out. I have been driving it some and I noticed slight spark knock on light acceleration. So I checked the timing and it was set at about zero or maybe even a degree or 2 after TDC!! So I set it up to 12 btdc and took it for a drive- spark knock big time! I also have a 71 Cutlass that I've owned for years. The 71 was set at 12 btdc but I found seems to run best at about 18 btdc. Both cars use 93 octane"premium" gas. I know the 71 has 8.5 compression and the 70 has 10.25, but could that make such a difference?? Also I believe the timing chain is quite loose on the 70, I think I can hear it. Or could the harmonic balancer slipped? Thanks for your thoughts, Greg.
Old Jun 15, 2013 | 06:59 PM
Yup.
Could be. You'll never know 'till you check.
Old Jun 15, 2013 | 07:26 PM
The harmonic balancer is easy enough to check, and the timing chain needs to be replaced.
Old Jun 16, 2013 | 05:51 PM
After checking it out further I am quite sure it needs a chain, the timing mark jumps around on idle, so that will be done this winter(unless it quits before then). I'm not going to go too far from home until then...I kinda rescued this car from being a parts car so it is to be expected, I guess... but I may have to get a MAW helmet- I don't want to end up rebuilding this engine!
Old Jun 16, 2013 | 07:31 PM
Is your spark knock at very light throttle only? If it is check you vacuum advance canister, disconnect it and see if it goes away.
Old Jun 19, 2013 | 05:58 PM
I'll try it. I checked everything out and the vac advance isn't leaking vacuum, in fact I didn't find any vacuum leaks except for some leakage at the carb throttle shaft. I will try it with the advance unhooked. Also I was thinking this old girl may have oil/carbon deposits- don't know how much oil it uses yet-has 176 (276?) thousand miles....
jpc647
Jun 10, 2013 11:48 AM
442scotty
May 13, 2009 05:42 PM
54olds
Jun 7, 2008 08:38 PM
Redog
Feb 26, 2008 02:50 PM
Huron
Mar 16, 2007 06:18 PM
