Am I crazy, or is this new timing chain awfully slack?
I picked up an engine recently, and checked the timing chain by reaching in through the fuel pump hole and moving it with my finger. It seemed loose to me, especially since it looks new, so I checked further...
Does this look W-A-A-A-Y loose to you? It's looser than I can recall a new chain being.
Thanks,
Thanks,
Seriously enough - This is not an old chain - it is clean and fresh-looking.
This is somewhere in the neighborhood of "horrifically poor manufacturing quality," is it not?
I wish I knew what brand it was, so I could tell people not to buy it.
Who says this is even the right chain for this engine?? Might not have anything to do with manufacturer. You and I both know that if you want something done right on your car (or new engine in this case) you don't necessarily accept what someone else has done as correct unless they have the credentials or receipts to back it up.
Is this a replacement for that worn out pavement ripping ground thumping tire scorching torque monster 260 in your Delta?
Good point.
Which is why I took it apart. You never know what the previous bozo (or the one before that) did.
Should be. It's a good-running, well maintained motor, which I can use without a major overhaul, thus allowing me to pursue a major overhaul at a more leisurely pace.
Looks like its got way too much slack for a new chain. I need to do that too to the 307 in my Riv for the same reason. Supposedly done on my motor too but when I changed the fuel pump, it felt too loose to me.
Nothing surprises me when Bubba's been in there.
Oh, no doubt about that.
Probably a 9-slot adjustable, as I like to confirm my cam timing.
I just thought the chain slack (on a new-looking chain) was amusing - my real question is how to ID this cam, so I know what the devil it is
.- Eric
Eric, you've already got the right answer. But just to have something to compare it to, here's a fresh 350 shortblock. The top picture is how it sets without pressure, the bottom I'm pressing inward with my finger. John
(And, no, this motor was never otherwise machined or rebuilt - it's very original, down to the carb., the distributor, and the grease deposits).
That's the weird part - it seems pretty messed-up to make a chain that slack.
Though, as Allan suggested, maybe it's a chain for a different motor
.Nice block, by the way - Glyptal'ed and everything!
Many many years ago I purchased a 1966 Ford Bronco with a 289. The idle was a nice rumpty rump, but when I put a timing light on it, it jumped all over the place. I was a teenager and still trying to figure out the difference between a crecent wrench and channel lock pliers, so I took it to a shop. They told me it had a 6 cylinder timing set in it
I don't know if that's really true, but they told me they put in a timing set and that fixed it.
How many times have you run into someone who thinks the Olds and Chebby's used the same 350 engines? The difference may be hard to measure, but if you put a fresh Olds set against these I wonder if you'd see some differences. John
I don't know if that's really true, but they told me they put in a timing set and that fixed it.How many times have you run into someone who thinks the Olds and Chebby's used the same 350 engines? The difference may be hard to measure, but if you put a fresh Olds set against these I wonder if you'd see some differences. John
I made the mistake of ordering this cheap, $27.95 chain, I figured it was Cloyes so it couldn't be too bad...
http://www.summitracing.com/parts/cl...ake/oldsmobile
This chain was slightly loose, but it had the worst heel/toe fitment I've ever seen. When you pull the chain tight against the sprocket you could see lots of daylight everywhere in between.
I had to further investigate this so I installed it on a low-budget 350 rebuild I had on a stand with a mild Lunati cam. This chain was 3.5 degrees off! I pulled it off and installed a BTR chain and it was within .5 degrees.
I'm not knocking all the Cloyes chains, I've had great results with the street true roller for $69.99 or the higher end ones.
Sorry for kinda highjacking Eric, but when I saw the pics you posted, it reminded me of this chain.
Albeit a single roller Eric, the cam gear looks worn and possibly missing a tooth @ 5 o' clock and the nylon teeth that took up some of the slack is prolly in the oil pan and John's pic is a double roller with new gears.
What engine is this anyway?
LOL
Reg'lar ol' 1968 4bbl 350.
Thanks,
Thanks,
