Can't get fuel pump out of my 86 cutlass supreme!
Old Feb 11, 2013 | 07:28 AM
1986cutty's Avatar
Hey everyone new here but I am in the process of replacing my fuel pump in my 1986 Cutlass Supreme with a 307. Right now I got it loose except for one of the hoses and I had to pull my a/c compressor to the side to get in there but the problem is that the long end of the fuel pump is keeping me from pulling it out what do I do?
Old Feb 11, 2013 | 09:29 AM
Uh, did you remove the A/C and A.I.R. pump brackets first?
Old Feb 11, 2013 | 09:59 AM
Octania's Avatar
turn the engine 1 turn or so, see if that gets the eccentric out of the way
Old Feb 11, 2013 | 10:03 AM
tru-blue 442's Avatar
Old School Olds
Originally Posted by Octania
turn the engine 1 turn or so, see if that get the eccentric out of the way
Yeah, that otta do it.
I'm thinking brackets also.
Old Feb 11, 2013 | 11:10 AM
oldsmobiledave's Avatar
my 2 cents
Just turn the engine ahead using a socket on the crank pulley or bump the starter. That will clear the eccentric & allow you to pull out the pump.
Or...you could pull that 307 & toss it on the scrap heap. Install a 330 a 350 or a 403 along with a good fuel pump & see if that helps!
Old Feb 11, 2013 | 11:13 AM
1986cutty's Avatar
Ok sorry I am in high school and I am learning as I go so please bare with me lol now i think i had already done that.
And oldsmobiledave, yea I know that is what I am going to do after this craps out on me
Old Feb 11, 2013 | 12:33 PM
So back to my original post...
And I might BEAR with you. Don't fall asleep in those English classes.
Old Feb 11, 2013 | 02:51 PM
DoubleV's Avatar
Step number one; scrap the entire AIR system. Step number two; enjoy how much easier it is to work on your engine with it gone.
Old Feb 11, 2013 | 03:38 PM
1986cutty's Avatar
If you mean the black metal piece right in front of the fuel pump then no because I couldn't get a bolt off and almost stripped it so i moved the a/c compressor to the side instead to get to it. But I still didn't believe that the fuel pump would be able to make that sharp turn so I never thought that I had to remove it. And sorry I don't usually use the saying much lol
And DoubleV I noticed that when I looked at other Cutlass's
Old Feb 12, 2013 | 06:34 AM
The fuel pump has a long lever that goes into the motor. You have to remove the A/C compressor completely, though you don't need to disconnect hoses, just remove the bolts and move it to the side.
Old Feb 12, 2013 | 07:22 AM
1986cutty's Avatar
I don't see how that is possible with the thing below the a/c compressor that the belt also goes around keeping me from pulling the fuel pump out
Old Feb 12, 2013 | 07:36 AM
TripDeuces's Avatar
You'll have to remove the belts too
Old Feb 12, 2013 | 08:35 AM
OK, back to basics.
1) Loosen the adjustment bolts on the A/C compressor
2) Remove the belt that goes around the A/C compressor and the A.I.R. pump
3) Remove the bolts holding the A/C compressor and lay it out of the way (do not disconnect the hoses)
4) Remove the A.I.R. pump (the thing below the A/C compressor). This will require removing the pulley to get to the mounting bolts. You will also need to disconnect the large hose on the back of the pump.
5) Replace fuel pump
6) Reverse the process above to reinstall everything.
7) Tighten belt.
Old Feb 12, 2013 | 12:29 PM
1986cutty's Avatar
Ok thank you at least im doing something right. And last question how do I remove the pulley without it moving when I try to remove the 3 screws on the A.I.R. pump?
Old Feb 12, 2013 | 01:03 PM
Er, yeah, sorry about that...
The trick is that you loosen (but do not remove) the bolts on the pulley BEFORE you loosen the belt. I should have mentioned that before.
Old Oct 5, 2020 | 08:50 AM
dinoedwards's Avatar
Is it possible to do this without removing a/c compressor and smog pump?
Old Oct 5, 2020 | 09:30 AM
Read the instructions below again you are not removing, you taking it loose and shifting the compressor out of the way.
OK, back to basics.
7) Tighten belt.
Old Oct 5, 2020 | 11:04 AM
Since you resurrected a SEVEN year old thread, I'm ASSUMING you read the instructions in Post #13...
Old Oct 5, 2020 | 02:16 PM
I did,,,but thought I wouldn't have to remove air pump but yep it's in the way.....so remove 3 screws holding pulley on and remove?
Old Oct 7, 2020 | 05:14 AM
This has nothing to do with the discussion, just couldn’t resist adding some light hearted smart-*** comments
Old Oct 7, 2020 | 05:17 AM
Being a smart-*** is always better than being a dumb-***.
Old Oct 8, 2020 | 03:07 PM
rocketraider's Avatar
Oldsdruid
I had forgotten how aggravating a 307 fuel pump job is. For that matter is anything on a 307 easy? Did the f/p on an 81 Pontiac wagon and cursed the people who designed it the whole job. Then when it needed valve cover gaskets I cursed their mamas and grandmas.
brown7373
Oct 25, 2014 11:13 AM
rket56
Brakes/Hydraulic Systems
Nov 30, 2013 03:45 PM
MDchanic
Apr 6, 2013 05:57 PM
Bottoms
Oct 6, 2010 10:50 AM
Flye
May 10, 2009 08:13 AM
