Power steering pulley
Old Jan 1, 2013 | 10:46 AM
jjokrm's Avatar
Do you need a special puller to take off the power steering pump pulley or just standard hand tools? I need to replace my power steering pump....reason I'm asking. Thanks.
Old Jan 1, 2013 | 11:02 AM
2blu442's Avatar
I'm not sure what year of setup your working on, but I've removed 1964-72 pullys with an air wrench on the nut, then I was able to slide the pully off with my hands.
John
Old Jan 1, 2013 | 11:05 AM
jjokrm's Avatar
Working with a 1968 rocket 350 setup. I'll give that a shot. Thanks!
Old Jan 1, 2013 | 11:09 AM
kitfoxdave's Avatar
I had to use a puller on my 72... Did come off fairly easily after that...
Old Jan 1, 2013 | 12:36 PM
Originally Posted by 2blu442
... I've removed 1964-72 pullys with an air wrench on the nut, then I was able to slide the pully off with my hands.
I've removed the earlier pulleys this way, by putting the pulley under the arch of my boot, then putting my weight on it, pressing it into a piece of timber on the ground, and reaching down and giving it a pop with the air wrench.
Should spin right off.
The later pulleys, DO require a puller, though (a pulley puller - about $15).
Old Jan 1, 2013 | 01:16 PM
The pulley is different between AC and non AC cars. The AC cars have 3 holes you can use to keep the pulley from turning while you turn the center nut. After the nut is undone the pulley should be able to come off with gentle tapping. It has a keyway on the spline that matches the key on the center of the pulley.
For non AC cars there is a special tool you can use (prolly rent) that is like a vice grip with a chain wrap. Snug it to the pulley (which is solid metal) to keep the pulley from turning. The bolt is not really that hard to get off with just a socket.
Old Jan 1, 2013 | 02:35 PM
Seff's Avatar
How will using the AC-type pulley affect a non-AC car?
Old Jan 1, 2013 | 02:42 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It shouldn't matter at all, unless you start mixing and matching pumps, pulleys and brackets.
Old Jan 1, 2013 | 02:46 PM
Seff's Avatar
My car is already a fustercluck of pulleys and belts - my alternator belt doesn't come off at all without me pulling the harmonic balancer pulley off. Right now my PS belt sqeaks, and I considered using the larger AC wheel off my spare to fix it.
Old Jan 1, 2013 | 03:36 PM
jjokrm's Avatar
Awesome! Thanks for the feedback guys. Much appreciated!
68Tom
Oct 24, 2010 07:55 PM
Steve Wike
Aug 22, 2010 06:45 PM
msco123
Mar 9, 2010 10:13 AM
oldsonharmont
Suspension & Handling
Feb 9, 2010 06:35 PM
mcutlass1969
Mar 26, 2007 07:09 AM
