Power steering pulley
Do you need a special puller to take off the power steering pump pulley or just standard hand tools? I need to replace my power steering pump....reason I'm asking. Thanks.
Should spin right off.
The later pulleys, DO require a puller, though (a pulley puller - about $15).
For non AC cars there is a special tool you can use (prolly rent) that is like a vice grip with a chain wrap. Snug it to the pulley (which is solid metal) to keep the pulley from turning. The bolt is not really that hard to get off with just a socket.
My car is already a fustercluck of pulleys and belts - my alternator belt doesn't come off at all without me pulling the harmonic balancer pulley off. Right now my PS belt sqeaks, and I considered using the larger AC wheel off my spare to fix it.
