plastic/nylon in oil pick up
Old Sep 11, 2012 | 07:27 PM
GmMike's Avatar
I am rebuilding my 350. took it apart and found plastic pieces in oil pick screen. timing chain was so loose that i could remove it with out taking off the gears. Was wondering if camshaft gear had plastic/nylon on it to reduce the chain noise in that engine?
Old Sep 11, 2012 | 07:31 PM
Yup. That's your culprit.
Old Sep 11, 2012 | 07:35 PM
jerseyjoe's Avatar
Yes the Olds engines used a nylon cam gear from the factory. You found what used to be the teeth in the oil pickup. A metal replacement gear is available.
Old Sep 12, 2012 | 05:39 PM
Octania's Avatar
I have some NOS plastic ones if need be
yes, they only last about 8 yrs/ 80k miles.
Old Sep 12, 2012 | 05:48 PM
GmMike's Avatar
OK thought that was it just needed the double check. I have new cam kit coming with timing set,lifters and springs.
RandyS
Oct 14, 2014 04:33 PM
defiant1
Aug 12, 2014 04:43 PM
1970VistaCruiser
Feb 23, 2014 04:17 PM
ctrain22
Aug 30, 2009 06:19 AM
