Getting a constant "code 41" on GM [FIXED]
Old August 2nd, 2012, 07:24 AM
Clydesdale's Avatar
Thumbs up Getting a constant "code 41" on GM [FIXED]
Just want to share this info in case someone else comes across this problem; might be posted here somewhere already.
Last Fall when I bought my 1989 Olds 88, the "Service Engine" light was ON; 3.8L. The guy I bought it from told me the service garage had changed several sensors and still couldn't find the problem. I've ignored it because I've only used this car 5 times since I bought it.
Last week, I hooked up the scanner & got code 41 which is the Cam Sensor. I replaced the sensor, cleared computer codes and yet, the "Service Engine" light was still ON. I did some research and found out that the Cam Magnet (interrupter) was the problem. It breaks off the cam sprocket. To fix this, you have to remove the water pump etc... or you can take a shortcut like I did and it works fantastic. See
Code:
http://padgett.performanceresearch.us/cars/cammag.htm
for step-by-step instructions. Credit goes to Padgett for the instructions.
Clydesdale is offline
Dead Reckon
Non-Olds Engines
December 7th, 2014 02:55 PM
starfire
August 31st, 2014 06:21 AM
senginc
Drivetrain/Differentials
January 2nd, 2012 08:52 AM
81 regency
April 21st, 2011 06:18 PM
jerseyjoe
Suspension & Handling
December 27th, 2010 12:54 PM
Quick Reply: Getting a constant "code 41" on GM [FIXED]
