accessory mounting
Old Mar 11, 2012 | 04:10 PM
Nasty455's Avatar
XCELERATIONRULES!
accessory mounting
I have the main pulleys...but don't remember how the alternator and power steering was mounted.
This 350 motor is going into a 71 Pontiac.
Any photos of your accessory mountings appreciated.
Thanks.
Old Mar 11, 2012 | 06:48 PM
2blu442's Avatar
Is the alternator on the driver side? Here's a few pictures, let me know what other views would help. John
First the Power Steering Pump. The picture with all the cobwebs (sorry, spiders are a real problem where I live) is a fastener into the side of the block, down near the oil pan. Then the arm with two holes close together, only use one of the holes and attach it to the front most exhaust manifold bolt. The two points that attach the water pump and timing tab both need threaded studs. Also, there's a spacer for the bolt down low into the block, and a spacer at the timing tab below the water pump
Old Mar 11, 2012 | 06:57 PM
2blu442's Avatar
Now there's several different alternator brackets that were used. Here's a few pictures, if you'll let me know which one you have I can try to get the mounting points a little more clear if needed.
First one
Second one, these pictuers are missing a tube that connects to the rear of the alternator.
Third one
Forth one
Fifth one, which is missing some parts but you can see its different from the forth one.
Old Mar 11, 2012 | 09:42 PM
Nasty455's Avatar
XCELERATIONRULES!
Thanks a million...makes the part search much easier.
I believe I have them..just have to find the box of parts.
Col Wickham
Oct 6, 2010 12:32 AM
DSM
May 17, 2010 10:30 PM
omg_its_nickels
Feb 16, 2010 11:13 PM
pontiac1
Dec 24, 2009 07:25 PM
Lady72nRob71
Jan 7, 2009 07:51 PM
