cheap performance parts or my 330 and will the 350 parts fit
Old Jan 16, 2012 | 01:51 PM
blaker1's Avatar
hey just bought myself a 67 cutlass hardtop 2 door with a 330 rocket and 2 speed tranny. anyone know of good places to score parts? i managed to get a holley intake on kijiji for 80 but i mean even a chrome waterneck ebay is 40 maybe im used to small block chevy parts bein so cheap but will 350 olds parts fit? say a cam etc? cant seem to find any places with performance goodies
Old Jan 16, 2012 | 03:48 PM
captjim's Avatar
Just curious, but in what way is a chrome waterneck a performance part?? That said, almost all small block Oldsmobile parts interchange, especially 350 parts on a 330. Intakes, headers, ignition, etc.
Old Jan 16, 2012 | 03:58 PM
blaker1's Avatar
sorry to offend performance AND dress up
Old Jan 16, 2012 | 06:39 PM
captjim's Avatar
Just busin' your chops a little, not being serious.
Old Jan 16, 2012 | 11:39 PM
64Rocket's Avatar
When you look for a cam, be sure to indicate that the 330 is a 45* cam bank angle. All Olds engine, 68 and newer are 39* cam bank angle.
Gene
Old Jan 17, 2012 | 02:39 AM
blaker1's Avatar
all in fun, so on the most part olds 350 performance parts and stock parts will all interchange on to my 330. because edelbrock holley comp cams etc all carry 350 olds stuff just no 330 any good websites out there ? thanx alot for your time guys
Old Jan 17, 2012 | 03:24 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have been told by my local olds racers a 330 can accept an overbore big enough to hold a standard sized 350 olds piston.
Old Jul 17, 2016 | 10:58 AM
Cutlass Fan's Avatar
Can someone what a cam bank angle is and how they changed it from 45 to 39 degrees.
Old Jul 17, 2016 | 01:19 PM
svnt442's Avatar
You don't change the lifter bank angle.
Old Jul 17, 2016 | 03:22 PM
The bank angle is the angle of the lifter bores with respect to the camshaft. Early blocks had a 45º angle and later blocks had a 39º angle. The angle is part of the block manufacturing process, so it's just a different manufacturing design.
Old Jul 18, 2016 | 05:35 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I believe your 67 is supposed to have the new 39 degree cam bank angle but I would double check. I would also stay away from that chrome water neck. I had two and no matter what they would not seal and I believe they are more like $20 at Summit. Parts are more expensive but they were built better and more durable than the sbc, mid 70's version especially and something unique under the hood. Keep an eye on the for sale here and on Real Olds Power for parts, people are much nicer here though and take our advice. We even have guys who were with Olds in their racing days, actual GM employees who have really neat stories. One of the best upgrades for performance would be a mild built 2004R overdrive trans and gear swap, the best of both worlds.
Old Jul 18, 2016 | 09:02 AM
70cutty's Avatar
Beer Connoisseur
Cheap and oldsmobile don't go together.
Old Jul 18, 2016 | 10:27 AM
So is camshaft higher in the block in the 45* bank angle to accomplish this? How is the angle measured.
Old Jul 18, 2016 | 11:10 AM
Oldsmaniac's Avatar
Yes this I also believe to be true and the 67 425 as well but always double check.
Old Jul 18, 2016 | 04:26 PM
70cutty Cheap and olds totaly go together lol just depends how you go about . 12.60's and i have less than 7k in my whole drivetrain trans and diff included. There is guys running much slower with 6k into a whole engine.
Old Jul 19, 2016 | 07:40 AM
70cutty's Avatar
Beer Connoisseur
That's not cheap.
Old Jul 19, 2016 | 09:50 AM
Like I said it's relative. If the average engine runs 6k alone then 7k for the whole deal ain't bad. Considering my usage aswell
Old Jul 19, 2016 | 12:46 PM
tmaleck's Avatar
My trick to getting chrome water outlets to seal is to remove the chrome plating from the gasket surface. I start with 80 grit and work up to about 220. I've not had one leak since I started doing that many years ago.
Tim
Old Jul 19, 2016 | 01:46 PM
oddball's Avatar
IIRC, everything is in the same place. The lifters just have a different approach to the cam, requiring different cam grinds (and usually different cores! a 39deg core is very difficult to regrind to a 45deg and vice versa, just not enough meat there). Unfortunately I don't know the engineering reason for the change.
Stick a well-fitting dowel rod in the lifter bore sticking up towards the deck. Place a ruler vertically on the deck with the edge up against the dowel rod. If the dowel and ruler stay aligned with each other then it's a 45deg lifter bank. If they diverge, then it's a 39deg bank. The actual angle is measured from vertical to the pointing angle of the lifter bank.
Old Jul 19, 2016 | 02:06 PM
Here you go:
And if you want even more information about it, see this thread.
Old Jul 19, 2016 | 04:28 PM
Correct, which is why the same timing chain fits both block styles. Actually, the same one is used for all second generation Olds engines.
Old Jul 19, 2016 | 06:20 PM
boese1978's Avatar
In simplest of terms- cam angle is the angle of the "V" in a V8 engine.
Old Jul 19, 2016 | 06:26 PM
ELY442's Avatar
X2, I use a cast iron type and it never leaked.
Old Jul 19, 2016 | 07:09 PM
Originally Posted by boese1978
... cam angle is the angle of the "V" in a V8 engine.
No.
The angle of the V is 90° in all of them.
Old Jul 20, 2016 | 06:54 AM
oddball's Avatar
A 90deg V8 is 90deg between the piston bank centerlines. There are narrower V engines. V6's tend to be 60deg, exotic engines can be more interesting. The lifter bank angle is just extra sauce thrown in. Lifter bank angles are all over the place in different designs, with some engines with really high cam locations having >50deg.
Old Jul 21, 2016 | 09:12 AM
Thanks oddball and Eric. Apologies to the OP for a bit of a thread hijack.
Old Jan 26, 2020 | 08:49 PM
67CutlassNut's Avatar
Congratulations!!!
i just picked one up myself.
Old Jan 28, 2020 | 06:43 PM
Originally Posted by 67CutlassNut
Congratulations!!!
What did you pick up?
1964F85
Aug 7, 2010 07:25 PM
wmachine
Dec 30, 2009 05:55 AM
esisson
May 22, 2008 07:47 PM
