1990 Cutlass Ciera engine question
Old Sep 17, 2011 | 02:13 PM
kona0197's Avatar
All I know about this engine is that it is a V6. My question is about the serpentine belt. does this belt run the camshaft as well? should it break do I have to worry about timing? How do I check it for wear and when do I need to replace it?
Car seems to run strong. Over 200K and still going strong.
Old Sep 17, 2011 | 02:42 PM
No. It only runs the accessories. The cam is driven by a chain under the front cover. Change it to your heart's content. Look for cranks on the underside as an indication that it needs to be changed.
Old Sep 17, 2011 | 09:14 PM
Redog's Avatar
Joe is correct.
If you have a V6, chances are you have on of the early 60* V6 engines in there. Very good engine
Old Sep 17, 2011 | 09:21 PM
kona0197's Avatar
Not sure what engine it is. I know it's a V6. says "3300" on the top in big letters. Fuel injected. I really don't trust fuel injection. How much MPG should I be getting?
Old Sep 18, 2011 | 06:31 AM
70 cutlass s's Avatar
Then you have a 3300 a very good engine, I use to own a 90 Buick Century that had a 3300. I remember getting around 25-28 mpg with it. The fuel injection system on this engine is simple, and easy to work on and very dependable. I would suggest getting a service manual if you plan on doing your own repairs.
Old Sep 18, 2011 | 10:27 AM
That's the 3.3 liter version of the venerable Buick V6 (more commonly seen in 3.8 liter size).
Old Sep 18, 2011 | 11:05 AM
kona0197's Avatar
The engine itself is really clean. Previous owner must have really taken the time to care for the engine. Somehow I would still feel better with a carburetor. Anyone know if the AC system uses the old coolant or new? I need to have it recharged.
Old Sep 18, 2011 | 11:42 AM
CQR's Avatar
CQR
The 3300 and the 3800 did have a nylon cam gear. They are an interference engine. They are a great motor but will wipe out the valves if the cam gear comes apart. At 200k miles I would think about having it done. Especially if you are planning on keeping the car.
Old Sep 18, 2011 | 12:17 PM
kona0197's Avatar
Would that be as easy as removing a cover on the front and replacing a chain like on a V8? How much would a mechanic charge for the service?
Old Sep 18, 2011 | 12:24 PM
CQR's Avatar
CQR
Yes, same principal as the v8, just a little tighter quarters since it is transverse. Parts and labor I would ball park it around $5 bones. Pm me if you want a closer estimate. I'll look it up for you at the shop tomorrow.
Old Sep 18, 2011 | 12:44 PM
kona0197's Avatar
$5 bones as in $500 bucks? I haven't seen that much money in a long time.
ducksalot
May 22, 2014 11:17 AM
Sparky1992
Mar 23, 2014 01:05 PM
blevans3
Jul 1, 2012 02:20 PM
katprice
Aug 14, 2011 09:37 AM
Big Dave
Dec 15, 2005 12:02 PM
