Cfm?
Old Jun 4, 2011 | 08:07 AM
BFitz's Avatar
Smile Cfm?
What is the difference between 700cfm and 600cfm? I am considering a new carb for 1972 Cutlass 350 with an electric choke. What will be the difference in results between the two?
Thanks!
Old Jun 4, 2011 | 08:16 AM
cutlassefi's Avatar
Pretty vague question, stock, modified? How much?
Old Jun 4, 2011 | 08:18 AM
Schne442's Avatar
No it's not a parts car!!
I've always heard that the 700 is too big for a stock 72 350. I had a 600 DP Holley in a 72 S that I had back in the late 80's and it ran great.
Gary
Old Jun 4, 2011 | 11:21 AM
BFitz's Avatar
It is a stock 350 4bb electric choke. Sorry and thanks.
Old Jun 4, 2011 | 01:01 PM
cutlassefi's Avatar
Do the 600.
Old Jun 20, 2011 | 09:35 AM
300F's Avatar
Hello I run a few Jears ago a 1968 350 with a 750 Carter mauall choke and the 350 liked it with nummber 5 heads on
this heads are high flow heads
Old Jun 20, 2011 | 07:46 PM
71 Cutlass's Avatar
One of None W-31
do the 600.
x2
Old Jun 20, 2011 | 08:18 PM
GAOldsman's Avatar
"Car"mudgeon
do the 600.
x3
Too much carb will slow you down
Old Jun 20, 2011 | 08:22 PM
GAOldsman's Avatar
"Car"mudgeon
Carb calculator. 600 is plenty
http://www.gtsparkplugs.com/CarbCFMCalc.html
Old Jun 21, 2011 | 05:58 AM
Quick rule of thumb. Cubic inches x 2=700 x .80 (80% efficiency) = 560. Go with the 600cfm.
Old Jun 21, 2011 | 07:24 AM
Jharken's Avatar
600 for what I think you have?
Old Jul 7, 2011 | 02:22 PM
captjim's Avatar
You guys kill me. The STOCK 4 bbl with manifolds was a 750. Also, those calculators are not accurrate in the real world. The 600 will work fine, but a properly tuned 750 is not too big, IMO.
Old Jul 7, 2011 | 10:26 PM
71 Cutlass's Avatar
One of None W-31
Stock 750 carbs were vacuum actuated and only put out what the motor demanded. If a 72 350 motor only demanded 560 CFMs from the carb, that's all it got. Stock Q-Jets didn't just deliver 750 CFMs b/c they were rated at 750. So the "stock" 750 argument is mute, not to mention the fact his motor is a 180 HP stock motor. No way he needs 750 CFM for that.
tim72
Jul 26, 2010 01:29 AM
Viz G
Aug 6, 2009 04:02 PM
delta881972
Jan 24, 2009 05:54 AM
fearthisrocket
Feb 18, 2008 06:19 AM
