Engine Build
Old May 17th, 2011, 10:17 AM
69cutdawg's Avatar
Engine Build
I really don't know that much bout fixing up engines bout I do know that I would like something like twin turbo or a supercharger. I want a **** load of muscle for my 1969 cutlass. I just pulled the engine out the this morning. But I need some info bout how to go bout settling the engine so it can be equipped
With either of the 2 I want to do.
69cutdawg is offline
Old May 17th, 2011, 12:57 PM
Hmmmmmmmm!
oldcutlass is offline
Old May 17th, 2011, 01:48 PM
firefrost gold's Avatar
were are you from ? I would find the best olds guy that is close to you. Work
with them to set up what you will need. Going that far into a project i would think about a ls or lx chevy type build, you can get lots of parts and update stuff for it jmo
firefrost gold is offline
Old May 17th, 2011, 05:56 PM
cutlassefi's Avatar
Procharger, when you're ready I can probably help. I have a buddy who's a dealer. I've thought about it many times myself. It's an nice way to make old iron keep up with the new stuff.
But you gotta figure a budget etc. Procharger alone will cost around 3k with the accessories, plus engine mods, but again a great way to go.
Keep us posted.
Mark
cutlassefi is online now
Old May 17th, 2011, 06:18 PM
69cutdawg's Avatar
What is the different between the 3 ? My goal is getting @ least 450 hp as a sleeper. My budget I had in mind was bout 10 grand on the complete engine. Will that be enoug?
Old May 17th, 2011, 08:25 PM
69cutdawg's Avatar
Dallas, Tx is where Im from, I'll appreciate it if you do refer me to the best olds person Near me
Old May 17th, 2011, 08:50 PM
Aceshigh's Avatar
Agreed.
450hp in a SBO isn't going to be cheap OR a sleeper.
Head flow is the real limiting factor in Oldsmobile engines.
It's going to sound radical and not be very streetable if its' NA.
John Lingenfelter Quote On Heads
"The worlds's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam and that engine will still make great power."
450hp in a BBO isn't going to sound like a sleeper either.
Just to give you an idea. SBO #6 heads flow roughly 180cfm @ .600 lift IIRC.
A modern GM 2007+ L92 head on a small block flows 320cfm @ .600 lift.
You'll get ~500hp in a LY6 GM Vortec 6.0L easily with just a S15 cam swap
and some Patriot Gold springs. You will be able to drive it daily and get great
gas mileage as well. http://www.ls1tech.com/forums/conver...ly-dyno-s.html
Aceshigh is offline
Old May 17th, 2011, 08:57 PM
Aceshigh's Avatar
I can't vouch for the SBO or BBO builds, but $10,000 will be MORE then enough to do a 500hp modern GM engine LS platform retrofit with sequential fuel injection, easy starts, and daily driver capable street manners and great MPG to boot.
I'm doing one right now and my budget is in the range of $7,000 including the 6 speed manual transmission. $5,000 for just the engine.
Aceshigh is offline
Old May 17th, 2011, 09:38 PM
Big Blue 72's Avatar
The responses you guys gave are great! I can't imagine the responses that this thread would have gotten on other forums!
Big Blue 72 is offline
Old May 18th, 2011, 05:57 AM
69cutdawg's Avatar
Thx to ones with the advice, this networking is new to me and is very helpful to me not knowing anything bout building an emgine
agreen316
December 21st, 2013 06:27 AM
wildwillie1981
April 24th, 2013 04:19 PM
805cut
May 3rd, 2012 08:11 PM
rml442
January 30th, 2008 02:10 AM
69 442 protour
December 9th, 2006 09:25 PM
Quick Reply: Engine Build
