Hot Intake Manifold
Hot Intake Manifold
Exhaust goes into the intake manifold to operate the choke
but can exhaust be blocked off from going into the intake.
My paint on the intake burnt. and no doubt the carburator gets very hot because intake manifold gets so hot.
Doesn't a cool carburator enhance power?
Why is the intake heated?
Sorry if this is a dumb question.
First what year is your car? 1973 and later have EGR and if you block off the crossover it won't function. Also if you don't change over to an electric choke the chock won't work and as the car warms up it won't run very well.
svnt442First what year is your car? 1973 and later have EGR and if you block off the crossover it won't function. Also if you don't change over to an electric choke the chock won't work and as the car warms up it won't run very well.
The main reason for the exhaust crossover under the carb is to promote fuel atomization, particularly when the engine is cold. The heat keeps the fuel vaporized instead of puddling out in the intake. Blocking the crossover is common when the engine is used in racing applications to get the last few percentage points of performance, but frankly for a street-driven car you want to keep the crossover open. Blocking it will make for poor cold start and driveability, especially if you live where it gets cold.
I installed a Performer RPM last year. I fitted the plugs and pounded them in. I thought I had them in tight, but they rattled so bad that I am now taking them out. It took about a month for them to get loose.
I ended up putting my crossover back in service. After about 8 years the gasket began to leak coolant so when I replaced them I removed the plates I had previously installed. It ran fine over the summer but took too long to warm up and run well when the temps got into the 50's. I like to drive my car until the first snow so it can get into the twenties. I have an electric choke but I would have to be very gentle on the gas for too long with the cold manifold. Runs much better now with the crossover restored.
shamusj
December 18th, 2014 09:28 AM
