Piston volume
Old Dec 30, 2010 | 08:46 AM
defiant1's Avatar
Question Piston volume
Trying to determine CR. Does anyone know the piston volume of the stock 1970 Olds 350? I have researched and cannot get a concrete answer. I have seen anywhere from 21 to 24cc.
d1
Old Dec 30, 2010 | 12:41 PM
captjim's Avatar
d1
The low comp engine will have 14cc dish, the high comp (which you probably don't have) will have a 6 cc dish. 71-72 350s all had a 23 cc dish. In 73 they went back to a 14cc dish and made the #8 head chamber larger to lower compression. Why the only available replacement is 23cc is beyond me..................
Old Dec 30, 2010 | 05:16 PM
defiant1's Avatar
Thank you sir. I still need to have the heads done. But this info will help in the final camshaft determination. Which I will pick your brain as well as cutlassefi on a good cam for my application.
d1
<wdd>
Oct 20, 2016 05:06 PM
Jolly Green
Dec 26, 2007 10:19 AM
68conv455
Dec 26, 2007 07:29 AM
Joel n
Jan 12, 2007 03:34 PM
72RocketPower
Feb 9, 2006 07:46 PM
