parts for '72 350 rocket???
hey there yall new user and i currently have an 86 cutlass supreme with the 72 350 rocket in it i need some help as to where to look for parts for it such as 4bbl intake manifold some new heads and an exhaust most everything i can find is for the chevy 350. any ideas on where i can look? thanks
The performer intake for the 307-403 Olds v8 is fine. You have good heads, if original. The only street heads are BBO Edelbrock RPM heads and need an electric fuel pump and a RPM intake due to larger ports. Along with those heads, new flat top pistons would be needed. Hedman Elite headers 58078? full length 78-88 with the SB Olds v8 or the Sanderson O351 rear dump headers fit well. With your low compression, either a 307HO or smog 455(pretty much the same) cam or something like the smallest Voodoo cam would do fine. Summit sells a G body dual exhaust, should fit well with the Hedman headers.
moys71
Feb 16, 2021 08:22 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
