Putting on fuel pump...eccentric...wtheck is that?
Old Aug 20, 2010 | 05:55 PM
rhett838's Avatar
68 Cutlass S Convertible
Is it just supposed to slide in there and fit perfectly? I'm just hitting something at the very back and it's not going on flush. do I bolt it on until it's tight against the block? or is it supposed to fit just right?
How do you get the fuel pump in there and manuver around the eccentric?. I'm off by ab 1/8th of an inch.
What are the tricks to doing it? eccentric means nothing to me BTW.
I need a you tube vid for this
thanks!
Old Aug 20, 2010 | 06:23 PM
Oldsmaniac's Avatar
Hmmm, seems something is wrong in Denmark..... On an Olds V8 the eccentric bolts to the large timing gear that bolts to the cam. The front cover needs to be removed. The arm on the fuel pump rests against the eccentric. You may need to turn the cam to get the arm on the low spot to bolt the fuel pump on easily.
Old Aug 20, 2010 | 06:32 PM
rhett838's Avatar
front cover needs to be removed?? are you kidding me??!!! I thought this was a 30 minute job?
i can turn the cam and see if that works, but if i have to take off the cover i gotta get it toewd to the mechanic...that's beyond my skill set
Old Aug 20, 2010 | 06:45 PM
Oldsmaniac's Avatar
Ok, you are just wanting to know how the fuel pump mounts....I guess I read too much into it...yes turn the engine some and when you reach the low spot on the eccentric the fuel pump will go right in.
Old Aug 21, 2010 | 06:48 AM
Or, don't turn the engine and just push in harder on the fuel pump so you compress the internal spring enough to get the fasteners started.
Old Aug 24, 2010 | 07:15 PM
rhett838's Avatar
got it...I just turned the engine some...thanks for your help!
512Lac
Apr 5, 2014 04:10 PM
Olds442redberet
Mar 11, 2013 08:24 AM
Derrick
Aug 31, 2011 11:25 AM
80_cutlass
Aug 30, 2009 01:46 PM
jr711
May 27, 2009 04:06 PM
