Is this Distributor Crooked?
Old May 12, 2024 | 05:36 PM
James J's Avatar
Dropped a new Summit HEI in my H/O. Unless I'm crazy the Old one was straight up & down. Wasn't sure if I should put the old one in. It does run the way it is. thanks Jackson
Old May 12, 2024 | 05:46 PM
Have you verified the cap is installed correctly, as in is it seated so the base of the cap flush all around?
Old May 12, 2024 | 06:56 PM
The cap does not look like it's on right.
Old May 12, 2024 | 07:06 PM
I wonder if the notch is not aligned properly, or if it’s not the right width and not letting the cap seat.
Old May 12, 2024 | 07:30 PM
Sugar Bear's Avatar
Distributor looks correct, the cap does not.
Old May 13, 2024 | 12:32 AM
Old May 13, 2024 | 01:34 PM
BackInTheGame's Avatar
To my eye the vertical shaft looks tilted, compared to the horizon (lower) that Joe shows.
Old May 13, 2024 | 07:58 PM
FStanley's Avatar
see this before notch in distributor not wide enough for cap to seat..
Old May 14, 2024 | 04:07 AM
BillK's Avatar
That is normal Here is a gm HEI in an Olds 350 that I am building.
Old May 14, 2024 | 10:43 AM
REO442's Avatar
Bill, are you showing a proper fit unit that is not square or perpendicular to the cam centerline?
Old May 14, 2024 | 10:59 AM
BillK's Avatar
Yes. The cam is in the engine and the base of the distributor sits flush and straight on the block. So the slant is normal. I was going to take a look at the 307 in my Wifes Riviera last night but just figured this would be a lot easier since that engine is on the stand and I had a couple of HEI's here at the shop.
I have never really paid attention to it but there are plenty of other engines where the distributor is not vertical in the block. It really does not matter if it is vertical in the block anyway. Chryslers are on almost a 45 degree angle
I just did a Google search of "350 Oldsmobile engine" and looked at a bunch of the pictures and there are quite a few where you can see the distributor leaning.
Old May 14, 2024 | 11:10 AM
BillK's Avatar
I just thought of another way to convince you guys Here is a picture of the oil pump shaft. The angle matches the distributor.
Old May 15, 2024 | 03:02 AM
The distributor is not perfectly vertical in an Olds motor, but the OP's problem remains the fact that the cap is not seated properly on the distributor body. We're kinda getting off track here.
Old May 15, 2024 | 03:21 AM
Is it possible the distributor cap indexing tab is not seated (correctly) onto the distributor housing? Maybe the distributor cap is faulty & contains two indexing tabs?
Old May 15, 2024 | 03:47 AM
The cap is molded plastic. It's highly unlikely that the mold magically grew a second indexing tab. The cap just isn't installed properly. We've spent a couple of orders of magnitude longer pontificating here than it takes to just re-seat it properly.
Old May 15, 2024 | 04:14 AM
BillK's Avatar
I actually think it is. Its hard to tell for sure because of the bracket thats in the way of the picture. The bracket makes it look like its not on but I think it is. I just put the cap on the one I have here and it looks about the same.
It would be nice if the original poster would give us an update
Old May 15, 2024 | 03:42 PM
Bill, I think you are correct. I went back and noticed this:
Old May 15, 2024 | 04:59 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
This really ain't Rocket science....or is it?
Is the key tab on the underside of the cap present and accounted for?
Is the key molded sharply?
Is it chineasium? If so scrap it and start over.
Push n Twist all 4 of the locks to get the L shape pointing outward.
Set the cap on the base and rotate it until the cap key tab engages and the cap seats on the base.
Push n twist the locks to point in towards the shaft. Done.
Look at each of the 4 screws. Are they equidistant down in the boss?
They should be at least 1/2 way down the hole when everything right.
They're spring loaded and should push back to squeeze the cap to the base.
If you are still having trouble get another cap and try it. And or to compare.
Old Oct 17, 2025 | 04:55 PM
FStanley's Avatar
$1 Million Dollars!!!!!!!!!
Old Oct 18, 2025 | 01:18 AM
Dynoking's Avatar
I don't know what the million dollars is for, but you are replying to a 17 month old thread.
88 Cutty Classic
Aug 14, 2016 06:59 AM
Seff
28
May 15, 2014 08:37 AM
EightyEightCut
May 1, 2013 07:48 PM
viper771
Feb 15, 2013 07:38 PM
Homestar
May 4, 2011 01:14 AM
