Cant figure out why 307 wont start
Old Jan 26, 2024 | 02:31 PM
thegrantler's Avatar
I just bought a pontiac firebird with a 307. I put a holley carb on and it would start and run. I had it running and it started spitting gas out the carb and caught fire and i had to dump a bunch of water to put it out. Only damaged some wiring and the distributor cap, so i replaced the wires, cap and coil and ran a positive wire to the cap for spark. It has spark on all cylinders, seems to have good compression and i cant get it to start with starting fluid. Any ideas?
Old Jan 26, 2024 | 02:51 PM
Does it buck or snort at least with starting fluid?
Old Jan 26, 2024 | 03:27 PM
If you literally dumped water down the carburetor - that water is still inside the intake manifold and most likely every single cylinder. You need to remove every spark plug, clean & dry every spark plug (or install new spark plugs) & clean/dry out the intake manifold & every cylinder probably with compressed air and allowing it to air dry for several days.
Old Jan 26, 2024 | 03:29 PM
Sugar Bear's Avatar
Is there a reasonable chance water got into the float bowl through a vent?
Old Jan 26, 2024 | 03:31 PM
I'd suggest better than a reasonable chance.
Old Jan 26, 2024 | 03:36 PM
STRONG SUGGESTION: If there's a reasonable chance it's still going to spit gas out the carb - DO NOT use H2O. Have a proper Class B extinguisher nearby. At a minimum a box of baking soda.
Old Jan 26, 2024 | 03:52 PM
Sugar Bear's Avatar
Was it still running when the water was dumped in the intake? If yes, the next step is a compression test.
Old Jan 26, 2024 | 06:03 PM
No it was not running and I already took the plugs out and extracted the water I just forgot to mention it in the post. With starting fluid it shoots some fire from the exhaust manifold but doesn't seem to try to actually start.
Old Jan 26, 2024 | 06:19 PM
Sugar Bear's Avatar
Still do a compression test if you can get a gauge.
Since the wires were replaced, confirm #1 is at TDC on the compression stroke, lift the distributor cap to confirm #1 plug wire aligns with ignition rotor, reinstall distributor cap and double check the firing order. Remember Olds distributors turn CCW.
Old Jan 26, 2024 | 07:09 PM
I felt it with my finger it felt strong, however i set the motor around 20 btdc according to the tab on thw front, and the distributor was pointing to cylinder 8. Nothing mechanical was changed so this doesn't make sense to me
Old Jan 26, 2024 | 07:34 PM
Sounds like your timing is way off.
Old Jan 26, 2024 | 08:06 PM
Sugar Bear's Avatar
Sounds like the wires are out of "clock position" on the cap. Either re-clock the wires on the distributor cap OR rotate the distributor like you are setting the timing until #1 wire aligns with the rotor.
Old Jan 26, 2024 | 09:05 PM
cjsdad's Avatar
Did you replace the wires in the correct order? Remember, Olds is still 1-8-4-3-6-5-7-2, but counter clockwise.
Old Jan 26, 2024 | 10:31 PM
Dumping water down the carburetor is huge. That can be the root of so many issues. Especially depending on how much water you dumped in there. Yikes.
Old Jan 27, 2024 | 02:57 AM
Since it is a 307 I @$$ume it's an HEI distributor. Did you remove the ignition module from the distributor for cleaning? Since you used water to extinguish the engine fire you should reapply heat sink paste to the bottom of the ignition module.
Old Jan 27, 2024 | 04:18 AM
1970cs's Avatar
Lansing built
What year Firebird? The early to mid eighties ran a 305 which is Chevy. All above would be correct and the firing order would be different and the distributor would turn clockwise. Can you post a picture of the engine bay?
pat
Old Jan 27, 2024 | 07:34 AM
Sugar Bear's Avatar
Pat, That's a good question!
@ thegrantler...where does oil get put in this engine, through the valve cover or through a vertical tube at the front of the engine? Depending upon the year I'm wondering if this could be a SBC, Pontiac or an Olds transplant motor.
A picture of the engine would be best.
Old Jan 27, 2024 | 12:07 PM
Its an olds transplant, not factory. I tried moving the distributor to align properly but didn't help. Also tried moving the plugs. I was thinking the timing was off but I just don't see how that could have happened from a fire or water being in there. All the stuff in the distributor didn't get wet and none of it got bunt, just the cap and wires. I've double checked the wire locations too
Old Jan 27, 2024 | 12:24 PM
Sugar Bear's Avatar
The timing would have changed if the ignition cables were off one spot in the place from where they were originally. Were the cables changed one at a time? If yes it is unlikely they are out of sequence.
Old Jan 27, 2024 | 01:50 PM
Yes i did but not based off of how they were to begin with. When i set it to where its on cylinder 1 at 20 btdc, it backfires out of the intake
Old Jan 27, 2024 | 02:27 PM
This means there is something wrong with your ignition timing. It could be anything from being wired wrong to distributor position.
Old Jan 27, 2024 | 02:46 PM
That engine being flushed with heavy amounts of water is no joke. You need to flush every angle off that motor. All the oil etc. You can't just go forward without doing that.
Old Jan 27, 2024 | 03:13 PM
I've already flushed it. How else should i set the timing? Thats the only way i know how
Old Jan 27, 2024 | 03:20 PM
From the beginning, you are not making this easy. A member asked what distributor you have. Is it a contact points distributor or an electronic ignition (i.e. HEI) distributor?
Old Jan 27, 2024 | 03:34 PM
You validated the spark plug wires are installed in the CORRECT (CCW) orientation for a OLDSMOBILE (307 cid) engine, correct?
Old Jan 27, 2024 | 04:21 PM
Thanks for posting the diagrams Norm.
Old Jan 27, 2024 | 06:32 PM
Sugar Bear's Avatar
Backfiring out of the intake, it may be 180 degrees out meaning the TDC when the distributor was installed was on the exhaust stroke it needs to be TDC on the compression stroke. At TDC compression the rocker arms on cylinder #1 are both closed and won't move if the crank is turned a little in either direction, the rocker arms on cylinder #6 are both closed at TDC but both will move very soon as you move the crank back and forth.
Put a compression gauge in cylinder #1 and confirm that it is at TDC compression. If you don't have a compression gauge you can either feel for the compression or put a tissue in the spark plug hole lightly and the compression will blow it out.
Old Jan 27, 2024 | 07:05 PM
It may sound lame but once you dump water into an engine that changes everything. Especially if you try running it after
Old Jan 28, 2024 | 04:54 AM
What a handy trick. I have used my finger over the spark plug hole to find TDC but never thought to use a tissue.
Old Jan 28, 2024 | 06:14 AM
I've done this also. It's pretty handy if you are by yourself and bumping the starter with the key. You can usually see the paper blow out from the driver's seat.
Old Jan 29, 2024 | 04:50 PM
  #31
Im pretty sure its an hei, the coil sits on top of the cap. All of the water was thoroughly flushed out along with new plugs. Nothing mechanical was changed so I don't know how the timing could be off. And the rotor only goes on one way along with the cap
Old Jan 29, 2024 | 06:22 PM
  #32
If you can't be sure what type distributor you have and you're guessing e.g. "...pretty sure it's an HEI..." you need to CONFIRM what type it is. Guessing buys you nothing. You're not making this easy. As has been suggested, post a picture of your engine bay and in particular your distributor.
If you don't know how to post a picture, read this >>> How To Post Pictures/Images
Old Jan 29, 2024 | 06:45 PM
  #33
Sugar Bear's Avatar
Can't take credit for thinking of it, a CO member brought it up a few years back...
Old Jan 29, 2024 | 06:50 PM
  #34
Bernhard's Avatar
X2
If the engine ran or was cranked with water in the cylinders you can hydrolock the engine.
Old Jan 31, 2024 | 02:11 PM
  #35
As i said, all the water was removed from the inside immediately after it happened.
Old Jan 31, 2024 | 02:20 PM
  #36
Sugar Bear's Avatar
That is a factory GM HEI distributor. Again if at all possible do a compression test before replacing any parts to rule out any internal engine problems.
Old Jan 31, 2024 | 03:19 PM
  #37
I plan to, it sounds the same turning over and the pressure felt strong with my finger but ill do an actual test when i get a chance
Old Jan 31, 2024 | 03:45 PM
  #38
70W-32's Avatar
Youre wire order on the cap is not correct
And did you replace the coil ground when you installed the new cap. I see a coil ground laying next to the old coil on the cowl
Is that distributor from a CCC car, I dont see a vacuum advance canister
Do yourself a favor and cover the carb opening with tape, or something, to prevent any crap from falling into the intake
Old Jan 31, 2024 | 03:50 PM
  #39
Sugar Bear's Avatar
I think 70W-32 is correct, the wiring order is wrong.
Old Jan 31, 2024 | 04:25 PM
  #40
Re-read Post #25.
NOTE: Firing order is CCW 1-8-4-3-6-5-7-2
