Another weird problem
Old Nov 2, 2009 | 11:06 AM
abram's Avatar
403 with a TH400, final touches, was turning it over yesterday and one of the tranny lines got extremely hot? Turned it over about six or seven times, checked for possible hot wires touching the line but didnt see anything, NO IDEA????
Al
Old Nov 2, 2009 | 05:07 PM
Bluevista's Avatar
Registered
It's grounding back through that line somehow? It needs a good ground especially when cranking and it could be searching for one or compensating for a weak ground through that line possibly, why only one though??
Check the main ground to the block and make sure it has a good contact. Also check the body to engine block ground straps and others like that, they're usually in a few places around the front end sheet metal and to the frame too.
Old Nov 3, 2009 | 07:12 AM
abram's Avatar
jeez, never even thought of that, I remember when i pulled the 350 out i busted the ground strap and forgot all about it, dumb dumb dumb! Thanks, now if i could only get the frost plugs to seal, but i have a fix for that, Again thanks for kicking my a**
Al
Old Nov 3, 2009 | 09:37 AM
jslabotsky's Avatar
Telecom Guru
It's easy to become blind to the simple things when you've been working on a big project. At least you noticed the problem and had the good sense to stop and think instead of ignoring it.
Old Nov 3, 2009 | 09:59 AM
Bluevista's Avatar
Registered
Al
I hope that's it.
Don't feel bad, I think we all have to learn that way, my butt is numb from being kicked so much.
Old Nov 4, 2009 | 08:07 AM
abram's Avatar
LOL, Thanks Fellas!!!!!
69350rocket
May 11, 2015 11:48 AM
Jim w
Nov 26, 2010 07:15 AM
The Stickman
Oct 25, 2009 07:04 PM
Joeypete
Aug 17, 2009 09:39 AM
chadnum1
Apr 30, 2008 11:12 AM
