Mysterious oil leak
Old October 26th, 2022, 02:16 PM
NorthBay72supreme's Avatar
Mysterious oil leak
I have an oil leak that I believe only occurs when the car isn't running. Tested this a few times and let her run in the garage for up to 20 minutes and at various RPM. The problem is - I can't locate the source of the leak. As you can see on the pictures below, oil is running down and dripping from a header tube. When I look at the top side of the headers in the engine bay, there is no sign of any oil whatsoever. I recently changed the valve covers and thought maybe the gasket got fudged a bit or I under/over torqued the bolts. That's not the case.
Where else should I look? I got under the car with good lighting, a mirror, and even a camera with a bright LED on a 36" flexible tube the thickness of a pencil. I can't see a damn thing.
SOS.
NorthBay72supreme is offline
Old October 26th, 2022, 02:27 PM
Sugar Bear's Avatar
Which side of the car?
Try to use a phone or a cell phone borescope to picture the back of the intake to block seal.
Good luck!!!
Sugar Bear is offline
deadeyejedi's Avatar
Intake end seal at the rear of the motor? your mirror might help here its tight quarters between the back of the motor and firewall.
deadeyejedi is offline
Old October 26th, 2022, 02:33 PM
pav8427's Avatar
Trick for some if these is to brake clean area then spray with Right Guard deoderant.
The residue the Right Guard leaves will let you see and trace leak to its source.
pav8427 is offline
Old October 26th, 2022, 02:34 PM
Driver's side. Man, looking in that area is tough. I'll give it a go.
Old October 26th, 2022, 02:35 PM
Will check it out, thanks.
Dude that's brilliant. Appreciate the idea.
Old October 26th, 2022, 04:23 PM
IMO, best method is to add a small 4oz bottle of fluorescent leak detection dye to the oil, run engine & visualize with a black light in a garage with all the lights off. Automotive parts supply stores sell dye and small pen light black lights. The leak will show up like an asteroid across the Southern sky.
Vintage Chief is offline
Old October 26th, 2022, 04:45 PM
What dipstick tube do you have? My money is on that as the leak.
joe_padavano is offline
Old October 26th, 2022, 07:11 PM
72Cutlass S
gs72's Avatar
what dipstick tube do you have? My money is on that as the leak.
word!!!
gs72 is offline
Old October 26th, 2022, 07:36 PM
Originally Posted by gs72
word!!!
x3
no1oldsfan is offline
Donaldbabineau
July 23rd, 2022 02:46 PM
Rilmar
May 6th, 2017 08:34 PM
Northern Custom Cruiser
April 22nd, 2016 07:07 AM
foreverolds
December 1st, 2012 07:07 PM
rmoths
November 22nd, 2012 12:07 PM
Quick Reply: Mysterious oil leak
