67 330 exhaust manifolds
Old Mar 12, 2022 | 03:25 PM
brianbeez67's Avatar
Just bought these exhaust headers and want to keep them from rusting. What products do you guys use?
Old Mar 12, 2022 | 03:54 PM
Sugar Bear's Avatar
Check out Bill Hirsch manifold paint. Any paint will eventually burn away but it will greatly slow the rust process. Would ceramic coating work... anybody???
Good luck!!!
Old Mar 12, 2022 | 04:46 PM
I've had good results with KBS. Use the brush-on, as it has a higher temp limit. The thinner in the aerosol version lowers the operating temp of the paint, according to the company.
https://www.kbs-coatings.com/xtc.html
Old Mar 13, 2022 | 05:40 AM
brownbomber77's Avatar
Performance Coatings in Jonesboro, GA was recommended to me from some of the Grand National guys for under hood heat. I had a set of long tubes for my daily driver done by them and held up just fine for 50,000 miles when I had em on the truck. Quick turnaround. Good work.
Old Mar 13, 2022 | 06:03 AM
Anderson's Avatar
I had some Pontiac SD manifolds ceramic coated in a cast finish and they look and have held up great. I’ve never had much luck with any header or high temp paint.
Old Mar 13, 2022 | 06:24 AM
I've had good luck with a product called cast blast.
88jetstar
Oct 4, 2021 09:34 PM
Roger60
Jun 8, 2017 09:55 AM
Roger60
Sep 20, 2015 04:00 PM
Sid
Nov 12, 2011 12:41 PM
wjustinmartin
May 17, 2010 06:12 AM
