Timing Advise - Idles better at 25 initial
Old Jul 20, 2020 | 03:28 PM
glamaina's Avatar
see my Sig for Engine Specs
I set my non vacuum advance idle timing to 18 and 34 at 3500 RPM. idle mix screws are set to MAX vacuum which is 15 in Park 11 in Drive. Drives fine this way. but ive been having idle issues. Anything under 850-900 idle RPMs in Drive and it will be ok sometimes but most of the time it will start to die and stall out. This is in Drive or Reverse with foot on brake. In Park it idles fine. I seem to need the in drive idle at around 900 to be stable which is just too high IMO.
After doing some reading on larger Cams and the timing I decided to play with the advance. I moved it to 25 at idle and its still at 34 at 3500RPM.
Well that seems to solve my idle issues. Its able to idle at 680 RPM in Drive and about 800 in Park with this timing.
question is, am I on the right path here. Any Cons to leaving the timing like this? Should I lower it back down to 18 and use the vacuum advance on the Manifold port to advance the idle timing instead of how im doing it now?
Oh and starts fine Hot at this timing, no overheating.
THanks,
Old Jul 20, 2020 | 03:51 PM
You need to see at what RPM your distributor advance stops. There is about 20* of mechanical advance built into an HEi distributor, so what ever your initial is set to you need to ad 20 to it and that should be your total. Apparently your not raising the RPM's high enough to see what your total actually is. I would set it at 16/18 initial and hook your vacuum advance to manifold vacuum. The vacuum advance can needs to be mechanically limited to 10*. I'm afraid with your current settings your going to run into detonation at the upper RPM's and cruise.
Old Jul 20, 2020 | 05:26 PM
glamaina's Avatar
Trying that now. Lowered it to 18 initial and I hooked up the vacuum to manifold and now I'm at 45 with the vacuum on the manifold so I have 27 worth of vacuum advance. Sounds highIhigh togto me.
I​ got it up to 3500 rpm I have to imagine that is enough to stop the advance. It stopped at 34 with no vacuum. So I'd say I have 16 mechanical which is close to the 17 I heard the Accel hei has in it.
So it sounds like I need an adjustable vaccum advance set that to about 10 and see if that fixes the idle issue.
Old Jul 21, 2020 | 07:47 AM
RetroRanger's Avatar
72 Olds CS
You can make a mechanical stop for the vac advance. Ken71 has posted several pics of his, i made one too. Its a little trial and error but if you have 27* of advance and you stopped it halfway its about 13.5* so if you add a little adjustability to your stop you can probably get 10-15* for a range.
moroso also sells one that achieves the sameish thing.
Old Jul 21, 2020 | 09:06 AM
glamaina's Avatar
I was looking for some adjustable advances and seems only crane cams makes one that comes with a mechanical stop plate. All the others are just cans that you can adjust the timing of the vacuum with an Allen wrench but can't adjust the overall advance. So that seems like the same concept as fabricating a stop yourself. I'll look into that.
Right now I reduced the initial to 14 with the advance on manifold I'm at 34 idle. At 3500 rpm I'm at 52 total timing with vacuum advance. I'll keep an ear out for knocking. But seems stable at idle.
Old Jul 21, 2020 | 10:05 AM
This is the adjustable stop that I made based on information that Schurkey posted. It's a 24º advance canister off a 78-79 403 HEI distributor and I originally just slipped a round bushing over the end of the shaft to limit its travel in the slot. That reduced the travel by 1/3, so it provided 16º advance (24º x 2/3 = 16º). I wanted to reduce it even further so I made the adjustable stop.
Old Jul 21, 2020 | 10:17 AM
dragline's Avatar
What carburetor are you using? With the car warmed up and idling, what happens when you pull a manifold vacuum line off, doe the idle go up or down?
Old Jul 21, 2020 | 10:23 AM
glamaina's Avatar
A brawler 770
In my current set up with 14 initial it will stall without the manifold vacuum line hooked up unless i jack the idle up to 900.
It seems to like 20+ of initial to stabilize the idle at lower RPMS.
Old Jul 21, 2020 | 10:25 AM
glamaina's Avatar
awesome thanks ive been endlessly searching threads to try to find these pics. looks like a simple mod. Im going to take it on the highway and see if there is any detonation with my current config before I bother doing this though.
Old Jul 21, 2020 | 11:22 AM
I assure you your timing is not stopping at 3500. There is probably another 3-5* if you increase it as normally and HEI has around 20* built in. With that said your probably ok with the 18*. Adjustable vacuum cans only adjust for rate based on vacuum available thats why a mechanical stop is required.
coppercutlass
Nov 2, 2019 05:36 PM
coppercutlass
Apr 15, 2018 07:25 AM
GHOSTOWLGRID
Jun 14, 2017 08:23 AM
Supernaut72
16
Sep 1, 2016 12:38 PM
russell-t
May 14, 2012 09:01 AM
