350 how to identifying casting numbers
Old Feb 1, 2020 | 11:21 PM
Timothy Davenport's Avatar
Rebuilt this 350 rocket engine. It has #6 heads.
Any forms
Top block cast #
Side of block #
Last edited by Timothy Davenport; Feb 5, 2020 at 06:07 PM. Reason: Forget the casting numbers
Old Feb 2, 2020 | 06:19 AM
Welcome. Your post title asks about casting numbers. Is there a question in there?
Old Feb 2, 2020 | 10:26 PM
sorry new to posting. Thought the pictures upload. Just edit the post. Could you help me ask least identify what year the motor was built? Allso is the #6 heads a good stock heads?
Old Feb 2, 2020 | 11:02 PM
svnt442's Avatar
The casting number indicates a 68-76 350 and the stamping indicates it came from a 1970 vehicle.
Old Feb 3, 2020 | 08:13 AM
Yes, that's a 1970 block and the #6 heads are also consistent with a 1970 motor. Stock CR should be 10.25:1 unless it's a 2bbl motor, which would be 9.00:1.
Old Feb 3, 2020 | 03:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What are your goals for the build? Where are you located? Either the Speedpro 6cc forged pistons or the Mahle Mahle 10cc piston is your best choice. Yes, the #6 heads are good but can be improved with W31 valves and porting. Cutlassefi on here, Mark Remmel has brought the Mahle pistons and many new parts for the Olds V8 to the market. Contact him, good guy to deal with.
ferndaleflyer
Sep 4, 2017 08:56 AM
beetemracing
Jan 29, 2016 11:49 AM
therealmikeb98
Oct 25, 2014 08:45 AM
bigmattg1
Oct 7, 2013 01:35 PM
esisson
May 22, 2008 07:47 PM
