Distributor gear oiling
Old Jun 2, 2019 | 05:35 PM
senginc's Avatar
I just read this on this website https://oldsjunction.classicoldsmobi...sfaq/ofign.htm.
" The oil rail (in an Olds) for the drivers side valve lifters ends just before the distributor. It should have a pipe plug with a .040" hole to spray oil on the distributor gear. If someone put in a plug with no hole, the gears and lower distributor bearing will have a short life. "
Can anyone confirm this ? I just built a 69 350 and used new oil plugs and they DID NOT have any lube hole.
Old Jun 2, 2019 | 07:13 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Yes this orifice is there for good reason. Non-Olds engine builder are clueless and continue to be...GAH
Old Jun 3, 2019 | 05:48 AM
senginc's Avatar
Where would you buy one of these plugs ? Do you remember the thread size ?
Old Jun 3, 2019 | 05:56 AM
boese1978's Avatar
I wouldn't run the car at all....plugs are out there, check some of the olds resto places.
Old Jun 3, 2019 | 06:14 AM
ELY442's Avatar
Take the plug out and get a drill bit that is .040" thick and drill in the center very slowly. The bit is very thin and brittle. This happened to me when I got my engine back from a machine shop. Its a good thing I checked it before I put the engine back in the car. Its a lot easier with the engine out.
Old Jun 3, 2019 | 06:15 AM
oddball's Avatar
You can drill the hole yourself easily enough. I drill a 1/16" hole most of the way through the plug then finish with a 0.040" bit. Very easy on a brass plug.
Or post a parts wanted. Several guys here have piles of the various plugs.
Old Jun 3, 2019 | 06:16 AM
senginc's Avatar
I have driven the car about 100 miles. I have had the distributor out about 10 times for various reasons and the gear is oily every time.
I may have used the original plugs and got lucky and put it in the right location, I hope.
Does the oily gear indicate that I may the orifice plug in there after all. What visual symptoms would there be if the orifice is not there ?
Old Jun 3, 2019 | 06:25 AM
senginc's Avatar
I wonder if I could use one of those borescope cameras would show the orifice by taking the distributor out ?
Old Jun 3, 2019 | 06:28 AM
senginc's Avatar
I wonder if I removed the distributor and spun the oil pump, if I could see an oil stream (like when priming the engine) ?
Old Jun 3, 2019 | 06:57 AM
boese1978's Avatar
Get a "dentist" mirror, pull the dist and take a look.
Old Jun 3, 2019 | 07:14 AM
tru-blue 442's Avatar
Old School Olds
Yes.
Old Jun 3, 2019 | 09:11 AM
senginc's Avatar
Smile
I made a small mirror and could not see hole in rear plug. Also no stream of oil when priming engine.
I made a few phone calls.
Tony Ross Racing says he has run without .040 orifice and says there is plenty of splash from rear crank counterweight, also timing chain is not a problem although the front plugs are unique and I reused them.
According to Mondello the factory did not have these oiling holes.
When I disasembled the engine it had only minor cam gear and distributor gear wear in over 100,00 miles of use.
Every time I pull the distributor after running, the distributor is dripping oil.
I will probably never put more than 5000 miles on the car in the next 10-15 years.
I'm 70 so the engine will probably outlast me.
442craig
Jul 24, 2019 11:41 PM
ajr2820
Mar 17, 2019 07:11 AM
85Cutty442
Nov 18, 2016 03:10 PM
lyev
Jun 14, 2015 04:08 PM
jankyrre
Nov 6, 2013 12:57 PM
