1968 400cid assembly
Old Nov 4, 2013 | 11:10 AM
jankyrre's Avatar
Hello.
Can anybody give me an advice on this?
The lubrication section in the SM says the distributor gear is lubricated by splash from the rear camshaft bearing.
The camshaft section says this lubrication is through a hole in oil gallery end plug.
This plug in my engine does not have a hole in it.
Old Nov 4, 2013 | 11:19 AM
cutlassefi's Avatar
I'm pretty sure it should. I've never taken one apart that didn't have it from the factory.
Old Nov 4, 2013 | 11:21 AM
72cuttys's Avatar
Halfway down the page - http://www.mondellotwister.com/OilingSystem.htm
A 3/8" pipe plug with a .040 oil hole in it to replace the stock left rear oil galley plug. If your oil galley plug does not have a .040 hole in it, you may experience excessive distributor gear and camshaft distributor gear wear. This plug is located behind the 29/32" freeze plug on the left rear side of the camshaft plug in the bell housing area. If left out, you could experience a serious drop in oil pressure. Sold each.
Old Nov 6, 2013 | 12:57 PM
jankyrre's Avatar
Getting the correct plug.
Minimal wear on the dist.gear even without the spray lubrication thought.
Next question:What is the best positions for the piston ring gaps?
Oldsragger
Jan 7, 2015 06:13 AM
stratoblues
Sep 1, 2014 06:52 AM
442tom
Dec 28, 2013 11:04 AM
wyteon
Jan 20, 2012 08:50 AM
2blu442
Jan 1, 2011 06:54 PM
