330 offset ground balance question in a 403 block?
Old Jan 2, 2019 | 05:13 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
After seeing Mark's response in the last thread; I now have my own question. What do slugs cost you guys down there each? I might get way with just two as long as my pistons actually weigh 550 grams along with the Scat sbc 2" journal rods. Does offset grinding make a balance difference? I know the Mallory will probably be double per slug up here for cost. Just making sure I won't get a huge shock on the final machining cost.
Old Jan 2, 2019 | 09:45 AM
cutlassefi's Avatar
Down here it’s about $75-80 per, installed.
Amd even though you’re reducing the journal size, and consequently it’s weight, you’re also putting the weight farther out by increasing the stroke. That will necessitate adding weight to the counterweights.
You’re probably in for 3-4 slugs total.
Old Jan 2, 2019 | 07:52 PM
Thanks Mark, that all makes sense. I will contact you in the near future for parts.
cdrod
Jan 1, 2019 11:12 AM
brownbomber77
Oct 28, 2018 08:07 PM
Via3d
Jun 10, 2018 07:54 PM
67Rocket
Aug 5, 2015 10:40 AM
hardrider442
Apr 30, 2007 08:19 PM
