330 question
Old Aug 4, 2015 | 09:10 AM
67Rocket's Avatar
330 question
Howdy, can a 330 block be bored out to use 350 pistons? If so, what piston would give compression around 10:1 with stock 330 heads, and can the 330 rods be retained? The engine is currently a 9:1. Thanks to all.
Old Aug 4, 2015 | 12:58 PM
Yes, it is possible, many have done it. 330 rods can be used with 350 pistons; CR will be dictated by head combustion chamber volume and piston-to-deck clearance in addition to the piston dish and compression height.
Old Aug 4, 2015 | 01:29 PM
GEARMAN69's Avatar
If you bore to a STD bore 350 , these will get you to 10:1 or a bit more right away .http://vi.raptor.ebaydesc.com/ws/eBa...=1438720056030
Old Aug 4, 2015 | 06:05 PM
67Rocket's Avatar
Sounds good, thx.
Old Aug 5, 2015 | 05:23 AM
GEARMAN69's Avatar
Here was the regular link http://www.ebay.com/itm/171018186784...784%26_rdc%3D1
Old Aug 5, 2015 | 05:24 AM
GEARMAN69's Avatar
If you want to back down to 9.5:1 use this in a STD 350 size http://www.ebay.com/itm/Speed-Pro-TR...d406fe&vxp=mtr
Old Aug 5, 2015 | 10:24 AM
67Rocket's Avatar
Great information, what cc's are the stock 330 heads? Thanks
Old Aug 5, 2015 | 10:40 AM
GEARMAN69's Avatar
About 4-5 cc smaller than 68-72 350 heads as delivered I think around 64-65 cc versus 68-69 cc , either way got to check them. Can be milled down to 60 cc easily
dave84
May 3, 2011 11:28 AM
JeremyTA
Feb 14, 2011 09:23 PM
Iragh
Jan 17, 2010 02:52 AM
Liegekiller
Jun 12, 2009 09:09 AM
hardrider442
Apr 30, 2007 08:19 PM
