350 piston/ring failure
Old Sep 23, 2018 | 05:03 PM
redbaron442455's Avatar
So I finally got around to pulling the oil pan on my father's 70' cutlass and here's what I found:
Peices of a ring and i believe peices of the pistons, probly more in the oil (nothing was magnetic)
1 skirt broken off
Another skirt broken off
I dont think you are supposed to see the oil ring are you?The cylinder walls looked pretty good from what I can see from the bottom.
anyone have any idea what might have caused this? Also can anyone help identify the pistons? 398665 cast into the inside of the skirt. Appear to have a very small dish thru the spark plug hole.
It was supposedly rebuilt about 10k miles ago, was running with some smoke coming out the breathers, 185-195 on all cylinders except #5 had 50.
Old Sep 24, 2018 | 06:40 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Detonation would be my first guess. Stock camshaft? What other build specs? What octane was used for gas?
Old Sep 24, 2018 | 06:57 AM
it was supposedly replaced with a "rv cam" only information I found on it was " 262 cam " on the rebuild receipt.
he would run 87 octane.
its stock 70 cutlass with outside air induction w25, th350, 2.56 rear, 2.5" exhaust, fel-pro head gaskets
Old Sep 24, 2018 | 09:43 AM
svnt442's Avatar
I bet that was making some nasty noises...
Old Sep 24, 2018 | 09:45 AM
I agree. Those pics look a lot like what happened to my '70 Supreme 350 back in the early '80s. One day I tanked up with cheap gas (poor college kid), then a couple days later was WOT sideways @5800 RPM and smoke started pouring out of the left side tail pipe. After tearing down the engine, I found a piston with broken top ring, ring land, and piston skirt, just like your pics.
Old Sep 24, 2018 | 10:05 AM
BillK's Avatar
398665 is a standard bore GM piston. Looks like the "rebuild" was a clean it up, hone it and put it back together type deal.
The broken ring was probably from detonation like the others said. The broken skirt is probably because the piston is way too loose in the bore.
Old Sep 24, 2018 | 10:41 AM
Ok I was thinking they were originals and they just re-ringed it, as far as the detonation goes he always said it runs great on reg 87, hes 75 and probly didn't hear it pinging haha,
thanks for the input, I've been looking at pistons available and this justifies going for the mahle 10cc dish pistons and running 91 octane instead of the stock replacement l2321 5.8cc dish pistons.
Old Sep 24, 2018 | 06:07 PM
Yes, a good plan. The only cam I can find matching a 262 duration, I assume is the 208/208 .445/.445 108 LSA Isky cam. That is a smaller cam and could put cranking compression high. Stock distributor and vacuum advance? Stock timing specs?
Old Sep 24, 2018 | 06:23 PM
It has the pertronix flame thrower distributor and coil. It was timed at stock initial timing I believe, maybe a few degrees advanced.
redbaron442455
Sep 7, 2018 04:35 AM
Swoopy
May 10, 2015 11:32 AM
mlouderback
Mar 29, 2011 11:56 AM
ctrain22
Aug 26, 2009 12:17 PM
The_Jeremiah
Dec 7, 2007 08:06 PM
