Installing temp,oil psi and volt meter
Old August 13th, 2018, 01:22 PM
Drsantos's Avatar
Any recommendation on a set of aux gauges for oil, temp and volt readings? Also are the available ports on the engine or do I have to tee of the idiot light sensors.
1969 Cutlass Rocket 350
Drsantos is offline
Old August 13th, 2018, 01:54 PM
I like the 270º sweep gauges as I think they're easier to read at a glance.
Something such as this:
https://www.amazon.com/Auto-Meter-2397-Autogage-Console/dp/B000CIL61M/ref=pd_lpo_vtph_263_bs_tr_img_1?_encoding=UTF8&psc=1&refRID=1E004RFTV21WFSM9E1WZ https://www.amazon.com/Auto-Meter-2397-Autogage-Console/dp/B000CIL61M/ref=pd_lpo_vtph_263_bs_tr_img_1?_encoding=UTF8&psc=1&refRID=1E004RFTV21WFSM9E1WZ
If you have the factory intake manifold, there aren't any places to install the water temp sender without removing something to make room. On my cars (when they had the factory intake), I removed the TCS and put the water temp sender in that port. With aftermarket intakes, there are additional ports that can be used for the temp sender.
For the oil pressure, you can T off the port for the idiot light.
Fun71 is offline
Old August 13th, 2018, 03:16 PM
Drsantos's Avatar
Thanks for the link just what i am looking for. in this photo is the sensor near the water pump (lower) the oil sensor, also is the one above water should the blue wire be connected there (why are there 2 tangs)
Drsantos is offline
Old August 13th, 2018, 04:12 PM
Yes, the one on the shelf behind the water pump is the oil sensor and the one beside the thermostat housing is the water temp sensor.
The wire should be connected to the water temp sensor for the HOT light to work properly, but two terminals on that sensor make me think it's not be the right one for your car. Maybe that's why the wire is disconnected?
Fun71 is offline
Old August 14th, 2018, 12:28 PM
Drsantos's Avatar
Does the green wire go to the water sensor, i believe it's wrong in the photo
Drsantos is offline
Old August 14th, 2018, 12:37 PM
Yes the green wire goes to the Temp sensor. I prefer to just stow the wires for the stock idiot lights as the resulting T and other mods to keep the Temp sensor are a pain and unsightly. The gauges are more accurate.
oldcutlass is offline
Old August 14th, 2018, 12:44 PM
Just don't install an amp meter, Please don't ask me how I know
Jamesbo is offline
Old August 14th, 2018, 01:21 PM
I won't ask as it's likely similar to what happened with my brother-in-law's '68 GTO one night while we were headed down a 2 lane highway on a camping trip.
I learned from that and put inline fuses on each side of the feed wires at the horn relay junction stud on my car.
I also learned that 12 ounce beverage cans, when shaken vigorously, can be used as under-the-dash fire extinguishers.
Fun71 is offline
Old August 14th, 2018, 01:27 PM
I shoulda had a 6 pack
Jamesbo is offline
Old August 14th, 2018, 03:02 PM
That was a sad day... RIP H/O
Old August 14th, 2018, 04:16 PM
therobski's Avatar
Here's a few ideas for you I got from another Club member here. I kept the "idiot" lights for the water temp and oil pressure. The oil pressure parts including the copper line from the unit to the gauge I bought at home depot.Looks neat and clean and it's like a redundancy plan, if one fails the other should work...and it does I have been having overheating issues and when the engine gets hot the light comes on the dash too. I chose not to use the plastic oil pressure line that came with the gauges. I removed my ammeter gauge for a gas gauge.
therobski is offline
Old August 14th, 2018, 04:31 PM
2olds's Avatar
https://www.summitracing.com/parts/atm-2399/overview/
2olds is offline
Old August 14th, 2018, 04:36 PM
2olds's Avatar
2olds is offline
Old August 14th, 2018, 05:05 PM
Drsantos's Avatar
Is there a second place on the intake for a temperature gage
Drsantos is offline
Old August 14th, 2018, 06:04 PM
Not with a stock intake.
Old August 15th, 2018, 06:07 AM
Drsantos's Avatar
Isn't there a electrical sender that could be used?
Drsantos is offline
Old August 15th, 2018, 06:24 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Be sure your water sensor is down in the intake. You cannot put a tee in for the water sensor like you can for the oil pressure.
redoldsman is offline
Old August 16th, 2018, 06:34 AM
JohnnyBs68S's Avatar
My 350-2bbl intake has a 2nd location for a temp sensor on the passenger side of the thermostat housing. That's where I put my temp sensor.
JohnnyBs68S is offline
Old August 16th, 2018, 06:55 AM
Rocketguy's Avatar
Some 60s cars cars had a two prong sender; one for the Hot lamp and one for the Cold lamp. If you don't mind the way it looks just be sure to connect the wire to the correct prong.
I'd also use the full sweep mechanical gauges, and go for the larger 2-5/8" size. I like the Stewart Warner gauges with the black face.
I'd also keep the warning lamps working, meaning use one provision on your intake for the lamp and the other for the capillary gauge line. If your engine gets hot you want to be altered if you aren't watching the gauge.
The oil is a bit more work. I think the T fittings at the water pump are ugly, and if you want your car to look stock, well. . . I drill and tap the oil filter adapter, and run a copper line along the back of the engine and up through the bottom of the firewall.
Rocketguy is offline
n_holman
May 29th, 2013 12:04 PM
jjokrm
December 27th, 2012 09:01 AM
olds88royalvert
June 11th, 2011 04:29 PM
plee3 64Olds
March 29th, 2011 09:20 AM
MJAKS462
April 15th, 2010 02:34 PM
Quick Reply: Installing temp,oil psi and volt meter
