303 Exhaust Manifold Bolts or Studs?
Old July 11th, 2018, 02:55 PM
Eightbanger's Avatar
Hey guys,
I bought a set of Headers for my 53 303, they are made by a company called http://noxiouscustoms.com/ when I fit them I'll need to replace the old Exhaust Manifold to Cylinder Heads studs, Fusicks have a set of new studs but don't keep new nuts for them, so I was wondering if anyone does a set of bolts instead for this application? I had a look at ARP but cant seem to find anything, or is it just best to keep with the studs?
Eightbanger is offline
Old July 11th, 2018, 03:09 PM
Phantom Phixer
Charlie Jones's Avatar
Yes , ARP's would be overkill . Besides , getting the studs out may be a problem .
Charlie Jones is online now
Old July 11th, 2018, 03:15 PM
Thanks Charlie, had those old studs out before, so that's ok, i'll just get a new set from Fusicks, any ideas on where I might get new nuts for the studs?
Old July 11th, 2018, 05:30 PM
Phantom Phixer
After looking at this situation , maybe short bolts would be better .
If you can find a source of U.S. standard bolts , then 3/8 -16 X 3/4 inch , grade 8 , bolts would be the thing to get . With 3/8 lockwashers .
Old July 11th, 2018, 11:18 PM
OLDSter Ralph's Avatar
3/4" + the header flange thickness ?
A place to try over there might be a Harley-Davidson dealer.
I would think they would have them on hand what you need and you wouldn't have to wait for them to arrive.
.....just my two cents worth
OLDSter Ralph is offline
Old July 13th, 2018, 05:09 PM
I've ordered new studs from Fusicks anyway, just in case! in the meantime i'll try and source a set of bolts.
Cheers Charlie.
Flange is 3/8 thick, so 1 1/4" total to include a lock washer? there are a few good American car parts stores over here, so hopefully they'll have em, waiting for stuff to arrive is a real pain.
Thanks Ralph.
I've highlighted the ones I think I need..??
Old July 13th, 2018, 08:58 PM
Cheers Charlie.
Thanks Ralph.
3.90 pounds for each bolt ? YIKES !!!! ARP is good, but you can get by with Grade 5 or 8 carbon steel automotive bolts.
1" would probably work fine. Screw the bolt in to bottom out and check. Grade 5 has 3 lines radially around the top of the bolt head, the Grade 8 has 6 lines.
Old July 14th, 2018, 03:40 PM
SWinner's Avatar
Check this site: http://www.allensfasteners.com/searc...rchParamCat=74
$.52 ea for 12 pt 3/8 16 X 1
SWinner is offline
Old July 14th, 2018, 04:00 PM
The OP is i another country (U.K.) and waiting for studs already. The larger hex head bolts will work better to bolt up exhaust headers than the small shouldered 12 pointers that are "half a world away".
Old July 14th, 2018, 04:14 PM
Thank you anyway for the link SWinner, that's a vast improvement on price.👍
Old July 14th, 2018, 04:34 PM
I know Ralph, they're silly money.😯
I found these.....any good?
https://www.westfieldfasteners.co.uk/UNC-Bolts-Screws/Hex-Bolt-Full-Thread-UNC-3-8x1-inch-A2-Stainless.html
rseungmina
January 23rd, 2016 03:09 PM
Tedd Thompson
April 13th, 2013 09:13 AM
woody30
September 17th, 2012 05:19 PM
dallasite21
February 16th, 2010 05:49 AM
dynamic88
November 27th, 2008 06:33 AM
Quick Reply: 303 Exhaust Manifold Bolts or Studs?
