303 Exhaust Manifold Bolts or Studs?
Old Jul 11, 2018 | 02:55 PM
Eightbanger's Avatar
Hey guys,
I bought a set of Headers for my 53 303, they are made by a company called http://noxiouscustoms.com/ when I fit them I'll need to replace the old Exhaust Manifold to Cylinder Heads studs, Fusicks have a set of new studs but don't keep new nuts for them, so I was wondering if anyone does a set of bolts instead for this application? I had a look at ARP but cant seem to find anything, or is it just best to keep with the studs?
Old Jul 11, 2018 | 03:09 PM
Charlie Jones's Avatar
Phantom Phixer
Yes , ARP's would be overkill . Besides , getting the studs out may be a problem .
Old Jul 11, 2018 | 03:15 PM
Thanks Charlie, had those old studs out before, so that's ok, i'll just get a new set from Fusicks, any ideas on where I might get new nuts for the studs?
Old Jul 11, 2018 | 05:30 PM
Phantom Phixer
After looking at this situation , maybe short bolts would be better .
If you can find a source of U.S. standard bolts , then 3/8 -16 X 3/4 inch , grade 8 , bolts would be the thing to get . With 3/8 lockwashers .
Old Jul 11, 2018 | 11:18 PM
OLDSter Ralph's Avatar
3/4" + the header flange thickness ?
A place to try over there might be a Harley-Davidson dealer.
I would think they would have them on hand what you need and you wouldn't have to wait for them to arrive.
.....just my two cents worth
Old Jul 13, 2018 | 05:09 PM
I've ordered new studs from Fusicks anyway, just in case! in the meantime i'll try and source a set of bolts.
Cheers Charlie.
Flange is 3/8 thick, so 1 1/4" total to include a lock washer? there are a few good American car parts stores over here, so hopefully they'll have em, waiting for stuff to arrive is a real pain.
Thanks Ralph.
I've highlighted the ones I think I need..??
Old Jul 13, 2018 | 08:58 PM
Cheers Charlie.
Thanks Ralph.
3.90 pounds for each bolt ? YIKES !!!! ARP is good, but you can get by with Grade 5 or 8 carbon steel automotive bolts.
1" would probably work fine. Screw the bolt in to bottom out and check. Grade 5 has 3 lines radially around the top of the bolt head, the Grade 8 has 6 lines.
Old Jul 14, 2018 | 03:40 PM
SWinner's Avatar
Check this site: http://www.allensfasteners.com/searc...rchParamCat=74
$.52 ea for 12 pt 3/8 16 X 1
Old Jul 14, 2018 | 04:00 PM
The OP is i another country (U.K.) and waiting for studs already. The larger hex head bolts will work better to bolt up exhaust headers than the small shouldered 12 pointers that are "half a world away".
Old Jul 14, 2018 | 04:14 PM
Thank you anyway for the link SWinner, that's a vast improvement on price.👍
Old Jul 14, 2018 | 04:34 PM
I know Ralph, they're silly money.😯
I found these.....any good?
https://www.westfieldfasteners.co.uk/UNC-Bolts-Screws/Hex-Bolt-Full-Thread-UNC-3-8x1-inch-A2-Stainless.html
dallasite21
Jul 15, 2025 08:22 AM
rseungmina
Jan 23, 2016 03:09 PM
Tedd Thompson
Apr 13, 2013 09:13 AM
woody30
Sep 17, 2012 05:19 PM
dynamic88
Nov 27, 2008 06:33 AM
