QJet Electric Choke Conversion
After searching the threads and finding the best way to convert from hot-air choke to electric on my 4bbl QJet, I wanted to inquire about the oil pressure switch that will be used as the keyed source of the choke. My current sender is the single spade unit which I have connected to a brass fitting as I have a set of aftermarket gauges to read the oil pressure. While the wiring suggestions utilize a 3-spade oil pressure switch (PN PS127), would I be able to simply remove the single spade and use the 3-spade switch instead? For all the options of available switches for my 70' CS 350, all of them are single spade. Just want to confirm before I make a mistake.
Joe P made a nice sticky on how to do this and most of your questions will probably be answered here:
https://classicoldsmobile.com/forums...ke-wiring.html
