Best halo style girdle for a 403?
Old Dec 2, 2017 | 10:05 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I know a few Olds specialists carry them. J&S is retiring, so not as sure about them . I am thinking a 5 main girdle. Are the thinner 4 main no machine girdles worth the effort? Light 550 gram pistons, Scat rods and a 330 offset ground crank. I just need a girdle , studs and cam bearings when I send it to the machine shop.
Old Dec 3, 2017 | 05:44 AM
cutlassefi's Avatar
3/8" 4 main from J&S would be more than adequate for your build.
Old Dec 3, 2017 | 08:19 AM
Kennybill's Avatar
I have one you might be interested in. I bought one from Jim at J&S about 15 years ago. Seeing as my Nephew is a tool and die guy, I had him make a copy only it's CNC'd not like J&S. I know, me bad. I never used it. No studs, and you would need to machine your caps. If interested pm me and I'll give you pictures/info yada yada. I'm in Ohio 44481. Thanks, Ken
Old Dec 3, 2017 | 10:31 AM
Super, no need to go over board. Do you know studs are needed with it? Mark I only plan on 9.5 to 1 compression with iron 350 heads with the bowls opened up, judt because I have them. I will be hitting you up for cam and other parts. It will be 424 ci and my plan is to have the short block done by next winter. Then add the heads with new positive seals, already machined for them and springs matched to the cam.
Old Dec 3, 2017 | 11:40 AM
cutlassefi's Avatar
Studs are always a good idea.
Old Dec 3, 2017 | 07:10 PM
Sorry Mark, I talking the part number for those studs. I know an align hone is also necessary with the Halo installed.
Old Dec 3, 2017 | 11:13 PM
76olds's Avatar
Hookers under Hood
I could CNC a Halo up for you, if you shoot me some dimensions. You can choose material. I will shoot you a price if you have the dimensions.
If other members would like one, I could do a group buy and knock the $$ down some.
Eric
Old Dec 4, 2017 | 04:23 AM
Hopefully I can get accurate enough dimensions. A CNC girdle would be more accurate, it is even possible to do a 4 main for around $250? That is what they go from the Olds specialist's, talking Canadian Dollars, which sucks compared to the US dollar these days.
Old Dec 4, 2017 | 07:48 AM
brownbomber77's Avatar
Does anyone know the part number for the studs themselves or is that something J&S puts together with ARP?
Old Dec 4, 2017 | 09:00 AM
Exactly, would like to know that also.
Old Dec 4, 2017 | 09:02 AM
cutlassefi's Avatar
1-4 would use the 1/2" longer SBF Main stud. ARP has a part number for it, just don't have that at my fingertips.
Old Dec 4, 2017 | 09:13 AM
Kennybill's Avatar
The thread starter pm'd me and I've replied. My CNC'd one is 0.4815" thick. Demensions exact duplicate of the one I bought except thickness. I couldn't put pictures in pm.
Old Dec 4, 2017 | 10:30 AM
Looks very nice.
Old Dec 4, 2017 | 11:41 AM
McGee68's Avatar
Is this one any good? Asking for a friend.. lol
https://www.ebay.com/itm/PRW-Billet-...xZiN75&vxp=mtr
Old Dec 4, 2017 | 03:40 PM
Kennybill's Avatar
The one on Ebay doesn't say anything about the stud kit. I got my ARP stud kit from Dick Miller Racing. I would question those studs. ARP studs are a little pricey but the goal is clamping strength so I wouldn't cheapen out on the studs. Jmo.
Old Dec 5, 2017 | 03:22 PM
76olds's Avatar
Hookers under Hood
[QUOTE=Kennybill;1059823]The thread starter pm'd me and I've replied. My CNC'd one is 0.4815" thick. Demensions exact duplicate of the one I bought except thickness. I couldn't put pictures in pm.
My apologies Ken! I should have read your post in detail and seen that you offered your's up for sale.
Eric
Old Dec 5, 2017 | 04:41 PM
76olds's Avatar
Hookers under Hood
[QUOTE=olds 307 and 403;1059767]Hopefully I can get accurate enough dimensions. A CNC girdle would be more accurate, it is even possible to do a 4 main for around $250?
1/2 Plate, its possible to make it cheaper here in Canada.
Eric
cut123
Aug 11, 2014 08:50 PM
67 Cutlass Freak
Jan 2, 2014 09:07 PM
cdaolds
Oct 26, 2013 02:12 PM
