fuel/air adjust with vacuum gauge does not work
Old Aug 4, 2017 | 12:55 AM
Haidda's Avatar
Hi guys, I do have a question that you can answer for me please. I tried to adjust fuel air ratio with my vacuum gauge but that does not work. I closes/plug #2 and #3 and put my gauge on #1. When I turn the mixture screw to adjust nothing happens - the needle on the gauge wont move. The same when I close/plug #1 and #2 and put gauge on #3.
Engine is warm, rpm is ok, timing is right. Quadrajet on a 1966 330cui olds with automatic and brake booster. What do I do wrong??
For # please see attachments
Do you know why. Thank you very much
BR daniel
Old Aug 4, 2017 | 04:31 AM
Hook your vacuum gauge to the port that has high vacuum at idle. If the 2 adjusting screws do nothing then your idle is too high and the engine is running outside of the idle circuit or you have a very large vacuum leak.
Old Aug 4, 2017 | 05:44 AM
^^^This. The easiest way to get the correct port is to NOT use one on the carb, but instead go directly to a port that screws into an intake runner. Typically the port used for the vacuum modulator on the automatic trans is a good choice. The trans does not need that to be hooked up when it's in PARK.
costpenn
Aug 29, 2018 11:42 AM
angelica
Sep 14, 2012 08:28 PM
Freddy B
Jul 21, 2012 06:41 PM
heritageadam
Apr 24, 2012 07:52 AM
GoBigRed
Jun 9, 2008 02:07 PM
