Intermittent high-pitched noise
Old May 4, 2017 | 06:48 PM
77ricbaez's Avatar
https://goo.gl/photos/VYhnCZkAQogZrYyr6
Here's a video of it. I'm stumped as to what that noise is, belts? Pinging? Something else?
Old May 4, 2017 | 07:15 PM
tru-blue 442's Avatar
Old School Olds
That alternator belt looks pretty loose. May want to tighten it and see if the noise goes away.
Old May 4, 2017 | 07:21 PM
76olds's Avatar
Hookers under Hood
How is the oil level Rick? Alternator belt is loose but I can't see it making that much noise. Put your hand on the fuel pump and see if its ticking, Sounds like exhaust leak in a way. Feel around manifolds, heat riser, and the egr etc. Hard to tell from the video. I don't think the timing chain would be hitting the cover but that could be a possibility to. Valves.. listen around the covers, pull the pcv and breather out of the covers and listen .
How many miles?
Eric
Old May 4, 2017 | 07:34 PM
77ricbaez's Avatar
Oil level is fine, recently changed too. I think it has 150,000 miles; never knew if it was 50,000 or 150,000 but ill assume the latter.
Also I forgot to mention but I had engine pinging on the highway so I retarded the timing a bit (was way too advanced, now it's slightly advanced @ 24*B at 1100 rpms). Test drove it, no pinging on the highway, hauled more *** when I stepped on it and idled smoother.
Then this noise showed up. Should I retard it a bit?
Old May 4, 2017 | 07:36 PM
76olds's Avatar
Hookers under Hood
Is it harder to start with it advanced that much? If its pinging when you step on it, retard the timing. You may be into a timing chain. Grab a piece of wood and hold it against the timing cover to see if you feel any vibration, noise etc.
Last edited by 76olds; May 4, 2017 at 07:39 PM. Reason: pinging under heavy throttle?
Old May 4, 2017 | 07:39 PM
77ricbaez's Avatar
No, it starts right up like it should. I don't think it could be the timing chain.. I would imagine that would sound a lot like a bad rattle.
Old May 4, 2017 | 07:42 PM
76olds's Avatar
Hookers under Hood
If it starts up like it should then your timing isn't way too far advanced. Try to pinpoint where the noise is coming from.
It could even be a bad motor mount that your fan is hitting the shroud. Process of elimination at this point. Tighten up your alternator belt as tru-blue mentioned and go from ther.
Old May 4, 2017 | 07:47 PM
77ricbaez's Avatar
Yes, its gonna have to be process of elimination. I feel like it could be a belt, it's just strange to me why this noise suddenly came out.
Like tru-blue said, it does look loose. Could be it but why the sudden noise is beyond me.
Old May 4, 2017 | 07:50 PM
76olds's Avatar
Hookers under Hood
You have oil pressure? Pump could be blocked with plastic from the original timing chain gear. Just guessing here Rick.
I hope its helping a little.
Eric
Old May 4, 2017 | 08:13 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Serrated style belt? Remove the belt then run the engine. Sounds like alternator or Serrated belt wine.
Old May 4, 2017 | 08:15 PM
77ricbaez's Avatar
Eric
Oil pressure is perfect and consistent in the 30-60 psi range
Old May 4, 2017 | 08:19 PM
77ricbaez's Avatar
The alternator belt looked pretty loose in that video. I'll check that next time I run the car
Old May 4, 2017 | 08:27 PM
I hate to say it, but I can't hear any unusual sounds in that video.
Old May 4, 2017 | 08:30 PM
77ricbaez's Avatar
It's a really high pitched intermittent sound.
Old May 5, 2017 | 07:49 AM
Originally Posted by mdchanic
i hate to say it, but i can't hear any unusual sounds in that video.
- eric
x2
Old May 5, 2017 | 08:18 AM
77ricbaez's Avatar
I didn't hear the noise this morning when I started it. We'll see if it comes back when it's warmed up.
And the alternator belt had a lot of slack on it. That may be the culprit like you guys said
https://goo.gl/photos/5NHHU7Cjmzj9Zq1Z6
Old May 5, 2017 | 12:45 PM
Old School Olds
Was that after you tightened up the belts?
Old May 5, 2017 | 02:33 PM
76olds's Avatar
Hookers under Hood
Dam!! you seem to be getting several gremlins lately that just come and go without returning both here and on the other site LOL. Maybe its your hearing going Rick haha.
Old May 5, 2017 | 02:43 PM
don71's Avatar
same but different
I throw this out there...
Sometimes if your coolant is low, you might hear some whistling or wooring noise that usually emits from the heater core. That "might" be a source.
Old May 5, 2017 | 04:19 PM
77ricbaez's Avatar
Thats true I've had some problems come and go, it's strange lol. The other day I had a little coolant leaking on the thermostat, I thought "oh great" but the next day it was gone.
As for the coolant, it is right where it should be. And the whistling sounds normal to me, my brother has a 307 olds on his 87 Regal and it whistles just like mine. That thing runs so nice and gets good fuel economy too!
My hearing? I'm still young!
Old May 5, 2017 | 04:24 PM
77ricbaez's Avatar
HAHA no I haven't done that yet. I tried to tighten it but I couldnt. Do I have to loosen the mounting bolt to the bracket too? I only loosened the adjusting bolt and tried to pull the alternator but nothing.
Old May 5, 2017 | 05:06 PM
Old School Olds
Ugg...It's a nice car, you could start with tight belts and see how it goes.
Or try this, in the morning, when the car is cold take all the belts off and fire it.
It takes a little bit for the engine to warm up so you can rev it a few times anyway, (3-4 minutes),
to listen, maybe post That vid, then at idle with a walk about....
I was with some of the boys, didn't hear much. I may have heard a lifter tick, but nothing out of the ordinary. How many miles does she have on her? I may have missed that.
Old May 5, 2017 | 05:29 PM
77ricbaez's Avatar
not sure, either 50,000 or 150,000 the PO never knew.
yeah she ticks when cold, but after warming up it quiets down
Old May 5, 2017 | 08:58 PM
77ricbaez's Avatar
ok so I checked the deflection on the alternator belt, it's 1/2" which is right on spec. I dont know about you guys but it looks to me that the power steering pulley is wobbling slightly
Old May 5, 2017 | 08:59 PM
Some carbs tend to whistle a bit. Power steering pumps make noise as they age. That belt looks loose.
Old May 5, 2017 | 09:11 PM
77ricbaez's Avatar
I know it does but the deflection is on spec.
Old May 5, 2017 | 09:49 PM
... the deflection is on spec.
With how much force applied?
Old May 5, 2017 | 10:05 PM
77ricbaez's Avatar
good amount of thumb pressure not sure roughly how many pounds that translates into
Old May 5, 2017 | 10:22 PM
Should be quite firm pressure, but not super hard.
You develop a feel for it.
There are also measuring tools (I have one, but never use it).
Old May 5, 2017 | 10:26 PM
77ricbaez's Avatar
Also what bolts do I need to loosen to be able to adjust the belt?
Just the mounting bolt, and the adjusting bolt?
Old May 6, 2017 | 04:19 AM
  #31
Loosen the slot and pivot bolts for all accys to adjust belts.
Old May 6, 2017 | 06:01 AM
  #32
stellar's Avatar
stellar
Take a look at the belt. If the sides of the belt are glazed (shiney and hard) it can slip even when tight and will need to be changed. If you change a belt recheck it after a few days of running time as a new belt will usually stretch some and it will need to be retightened. After the initial stretch and readjustment it will keep the tension for a long time. Also be sure to use a belt with the correct width. The 1/2 inch play is a good rule of thumb but isn't a definite factor as to belt tension being enough to not allow slip.Other factors such as belt and pulley condition and distance between pulleys are. If you have a rope streched 20 feet and there is a 6 inch deflection it is pretty tight, but if the rope is only stretched 5 feet and there is a 6 inch deflection it is loose. I have found the best way to check alt belt tension is to grab the alt fan and turn it. If the alt belt and crank pulley does not move with the alt pulley the belt is loose. Some cars will have another belt (usually PS) that drive the alternator belt. In this case the alt belt may turn with the alt pulley but the crank pulley won't move. If this happens the drive belt needs tightened.
Old May 6, 2017 | 08:43 AM
  #33
77ricbaez's Avatar
All right thank you guys for all the information!
Old May 16, 2017 | 06:54 PM
  #34
76olds's Avatar
Hookers under Hood
Any updates Rick? Was the alternator belt the issue?
Eric
Old May 17, 2017 | 10:09 AM
  #35
77ricbaez's Avatar
I think it was, I tightened it and now i don't hear it
still a bit floppy but it's not bad.
coldfire
Jun 29, 2013 07:39 PM
lsutigers93
Aug 17, 2012 06:39 PM
68442Convertible
Jul 5, 2012 10:25 AM
Rocketbrian
Mar 23, 2012 08:54 PM
henryk8398
Ninety-Eight
Jan 16, 2011 04:27 PM
