Intermittent high-pitched noise
https://goo.gl/photos/VYhnCZkAQogZrYyr6
Here's a video of it. I'm stumped as to what that noise is, belts? Pinging? Something else?
How is the oil level Rick? Alternator belt is loose but I can't see it making that much noise. Put your hand on the fuel pump and see if its ticking, Sounds like exhaust leak in a way. Feel around manifolds, heat riser, and the egr etc. Hard to tell from the video. I don't think the timing chain would be hitting the cover but that could be a possibility to. Valves.. listen around the covers, pull the pcv and breather out of the covers and listen .
How many miles?
Eric
How many miles?
Eric
Oil level is fine, recently changed too. I think it has 150,000 miles; never knew if it was 50,000 or 150,000 but ill assume the latter.
Also I forgot to mention but I had engine pinging on the highway so I retarded the timing a bit (was way too advanced, now it's slightly advanced @ 24*B at 1100 rpms). Test drove it, no pinging on the highway, hauled more *** when I stepped on it and idled smoother.
Then this noise showed up. Should I retard it a bit?
Is it harder to start with it advanced that much? If its pinging when you step on it, retard the timing. You may be into a timing chain. Grab a piece of wood and hold it against the timing cover to see if you feel any vibration, noise etc.
Last edited by 76olds; May 4, 2017 at 07:39 PM. Reason: pinging under heavy throttle?
If it starts up like it should then your timing isn't way too far advanced. Try to pinpoint where the noise is coming from.
It could even be a bad motor mount that your fan is hitting the shroud. Process of elimination at this point. Tighten up your alternator belt as tru-blue mentioned and go from ther.
Yes, its gonna have to be process of elimination. I feel like it could be a belt, it's just strange to me why this noise suddenly came out.
Like tru-blue said, it does look loose. Could be it but why the sudden noise is beyond me.
I didn't hear the noise this morning when I started it. We'll see if it comes back when it's warmed up.
And the alternator belt had a lot of slack on it. That may be the culprit like you guys said
https://goo.gl/photos/5NHHU7Cjmzj9Zq1Z6
haha.
As for the coolant, it is right where it should be. And the whistling sounds normal to me, my brother has a 307 olds on his 87 Regal and it whistles just like mine. That thing runs so nice and gets good fuel economy too!
My hearing? I'm still young!
Or try this, in the morning, when the car is cold take all the belts off and fire it.
It takes a little bit for the engine to warm up so you can rev it a few times anyway, (3-4 minutes),
to listen, maybe post That vid, then at idle with a walk about....
I was with some of the boys, didn't hear much. I may have heard a lifter tick, but nothing out of the ordinary. How many miles does she have on her? I may have missed that.
Ugg...It's a nice car, you could start with tight belts and see how it goes.
yeah she ticks when cold, but after warming up it quiets down
ok so I checked the deflection on the alternator belt, it's 1/2" which is right on spec. I dont know about you guys but it looks to me that the power steering pulley is wobbling slightly
Take a look at the belt. If the sides of the belt are glazed (shiney and hard) it can slip even when tight and will need to be changed. If you change a belt recheck it after a few days of running time as a new belt will usually stretch some and it will need to be retightened. After the initial stretch and readjustment it will keep the tension for a long time. Also be sure to use a belt with the correct width. The 1/2 inch play is a good rule of thumb but isn't a definite factor as to belt tension being enough to not allow slip.Other factors such as belt and pulley condition and distance between pulleys are. If you have a rope streched 20 feet and there is a 6 inch deflection it is pretty tight, but if the rope is only stretched 5 feet and there is a 6 inch deflection it is loose. I have found the best way to check alt belt tension is to grab the alt fan and turn it. If the alt belt and crank pulley does not move with the alt pulley the belt is loose. Some cars will have another belt (usually PS) that drive the alternator belt. In this case the alt belt may turn with the alt pulley but the crank pulley won't move. If this happens the drive belt needs tightened.
