Carb pump diacharge nozzle
Old Sep 24, 2016 | 12:29 PM
Mike Sundy's Avatar
Hi all,
I was about to put my carb back on when I noticed it is missing a nozzle. What is the best way to determine what size I need? Would it be the same as the other one?
Thanks,
-Mike
Old Sep 24, 2016 | 12:35 PM
Originally Posted by Mike Sundy
Hi all,
No it isn't. Your vac secondary carb only has one accelerator pump, not two. There are no secondary nozzles.
Old Sep 24, 2016 | 12:40 PM
Mike Sundy's Avatar
Ok, thanks. It just looked like something went there...
Old Sep 25, 2016 | 06:01 AM
Holley used that same main body casting on a lot of different carbs. Some had two squirters, some didn't.
Old Sep 25, 2016 | 05:00 PM
svnt442's Avatar
That looks a ton like an 1850 to me. 600 CFM vacuum secondary with a single feed to the front bowl and a transfer tube for the rear bowl and a single accelerator pump.
EightballZ
Aug 26, 2015 11:02 PM
1966 442
Apr 23, 2013 06:16 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
sshriber
Mar 22, 2010 06:16 PM
72Ctlss
Jun 23, 2009 03:12 PM
