Looks pretty good for a 260
Old Apr 7, 2016 | 08:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I kind of wish I kept my SP2P intake but who would have thought I would buy a car with a 260. I used the EGR block off from the Performer intake on my shelf and painted everything under the hood, 45 years worth of rust. Used high temp aluminum paint on the manifolds, Rustoleum Aged Copper on the motor and gloss black on the air cleaner and brackets. My Oldsmobile 10" air cleaner lid fits the stock air filter perfect, just need an extension to fasten it on.
Old Apr 7, 2016 | 08:49 AM
Inline's Avatar
Does it burn rubber?
Old Apr 7, 2016 | 10:01 AM
Yes with the gravel on top of the pavement from winter. With the true dual exhaust, it sounds good and adds power everywhere, making the 260 tolerable. I should run it down the 1/8 mile once, just to see.
Old Apr 7, 2016 | 10:19 AM
Inline's Avatar
Then its like my really tired 350, burns rubber with one tire on wet asphalt
Old Apr 7, 2016 | 11:06 AM
Which is good, won't burn off the hard to find 215/75R14 tires. The 350 in the 88 CSC leaves about a 30 ft strip on dry pavement.
Old Apr 7, 2016 | 11:12 AM
Octania's Avatar
So, you gotta change your user name then?
see also
http://www.hotrod.com/how-to/engine/...e-260-olds-v8/
Old Apr 7, 2016 | 12:19 PM
If anything I would change it to Olds 350 and 424. The 260 is not a long term motor, just a stop gap.
RROLDSX
May 5, 2014 06:36 PM
gearheads78
Jun 19, 2011 08:37 PM
NightStalker
Mar 19, 2011 06:51 PM
57 rocket
Feb 2, 2011 07:03 AM
