Quadrajet rebuild
Old May 20th, 2016, 05:39 AM
  #81
It's a Cutlass.
jeff in colorado's Avatar
I should only need one of those, my re-build kit should have one in it (I think). I checked it over quick when I got it two months ago but left it all sealed in the bags until I was ready to go trying to not lose anything.
jeff in colorado is offline
Old May 20th, 2016, 08:14 AM
  #82
It's a Cutlass.
secondary metering rod hangar screw. That's it.
Old May 20th, 2016, 09:59 AM
  #83
Y'know...
You don't necessarily need to keep the spacer.
Millions of these cars were made without them and ran fine for billions of miles.
MDchanic is offline
Old May 20th, 2016, 10:01 AM
  #84
If your carb were a straight-up '73 carb, that screw would be a regular phillips head, so this carb has been industrially rebuilt or otherwise messed with in the past.
MDchanic is offline
Old May 20th, 2016, 10:21 AM
  #85
I also need a smaller than T10 for the secondary... crap I forget the name. Anyway I tried the smallest torx I have and it's too big.
While we can't know for sure what a rebuilder might have used, the 1980s vintage Qjets used a T8 torx screw from the factory to hold the secondary metering rod hanger.
joe_padavano is offline
Old May 21st, 2016, 05:56 AM
  #86
It's a Cutlass.
What I'm thinking (knowing I know next to nothing about the subject at hand). The spacer was in the car, it ran decent, just some minor issues with the choke and slight fuel leakage. Maybe I could have tightened everything up and sprayed a can of carb cleaner down the throat, worked on the choke a bit and been fine. Since I decided to re-build, it seems like it won't hurt to keep the spacer in, and could help some. I absolutely appreciate and will do my best to follow the tips and vast knowledge gleaned here, but like all things, at times it comes down to opinion so it makes it that much more difficult for the novice to know what to do. I'm not complaining at all, just early morning gabbing.
I will try to post more pictures in the hopes it will help someone else (and me!).
Old May 21st, 2016, 06:02 AM
  #87
My gut feel is that in your application, the spacer isn't going to make a noticeable difference one way or the other. The only downside of keeping the spacer is that there is one more potential vacuum leak source (the spacer to intake gasket), which is negligible. The other thing is that when I go back and look at the photos you posted on the first page of this thread, it looks like the spacer may have been installed to provide clearance for the throttle arm on that aftermarket intake.
Old May 21st, 2016, 06:07 AM
  #88
It's a Cutlass.
there was some fuel, and possibly oil (?) in the spacer cavities. How could oil get in there?
Old May 21st, 2016, 06:09 AM
  #89
It's a Cutlass.
That's kinda what I'm saying, if I were to take the spacer out, what else would I have to adjust/change? My laziness and lack of confidence says keep it in (as long as there's no good reason to leave it out).
Old May 21st, 2016, 06:11 AM
  #90
It's not oil. Most likely is discolored and thickened fuel. The most volatile parts of the gasoline evaporate, leaving the thicker parts behind. Discoloration comes from contact with air, gasket material, etc.
Old May 21st, 2016, 06:27 AM
  #91
It's a Cutlass.
ok, good. Now I have a couple more questions. I don't have a vacuum gauge. For the pulloff, if I draw air in with my mouth from the vacuum line and cover the end with my tongue (quit laughing) and it holds for a few minutes, is that sufficient to test it. Or do I need to quit being so cheap and buy a gauge, or new pulloff? Also the lever for the accelerator pump in an earlier picture shows it barely contacts the rod, is it ok to bend the arm a little for more positive contact?
Old May 21st, 2016, 06:31 AM
  #92
If the pull off holds, it's fine. You still need a vacuum gauge, however, to properly set the idle mixture. They aren't expensive. Accelerator pump arm is set as part of the required adjustments in a proper carb rebuild. Your Chassis Service Manual details those adjustments. There was a PDF of the carb rebuild chapter way back in Post #3 of this thread.
Old May 21st, 2016, 06:51 AM
  #93
It's a Cutlass.
thanks again. I will read more, and go buy a vacuum gauge, and torque bit(s).
Stay tuned! hahah, get it?
Old May 21st, 2016, 06:52 AM
  #94
Torx, actually, and don't be surprised when a T8 is difficult to find.
Old May 21st, 2016, 01:28 PM
  #95
It's a Cutlass.
Hi!
I found the torx bit, only had to spend 7 dollars for a kit. Didn't buy a vacuum gauge, it's complicated. I took a ridiculous amount of pictures, have the air horn and parts off, cleaned, getting close on the fuel bowl stuff. Photobucket is giving me agita, but I'm trying to put some pics up. Meanwhile: the LBMF spring on top of the needle was missing, pretty sure I didn't miss it. How can that be? The new one comes with a spring and I assume the circular part goes on the reduced section on top of the needle. Yes?
Old May 21st, 2016, 01:32 PM
  #96
I can't exactly explain it without having it in front of me, but the needle hanger goes on the float in exactly the way that you would think it shouldn't.
I'm sure there are dozens of pictures if you Google it.
MDchanic is offline
Old May 21st, 2016, 01:33 PM
  #97
It's a Cutlass.
Old May 21st, 2016, 01:34 PM
  #98
It's a Cutlass.
Old May 21st, 2016, 01:36 PM
  #99
It's a Cutlass.
thanks Eric, not sure we're talking about the same thing. The last picture I posted is the part that had no spring, but one is shown in the instructions with the carb kit, as well as provided in the parts. Obviously NOT the spring that rolled into the picture above.
Old May 21st, 2016, 01:40 PM
  #100
The pump discharge ball and pump discharge ball retainer do not have a spring between them.
MDchanic is offline
Old May 21st, 2016, 01:41 PM
  #101
It's a Cutlass.
more fun pictures.
how I remember where some screws go.
Old May 21st, 2016, 01:43 PM
  #102
The two long screws can only go in one place.
The two countersunk screws can only go in one place.
All the other screws go everywhere else.
I don't think I've ever seen a metal shim where the float pivot goes.
There were many minor construction variations, but I don't think that's one of them.
MDchanic is offline
Old May 21st, 2016, 01:44 PM
  #103
It's a Cutlass.
ah, what's the hardest thing for people to do effectively? Communicate... It's me I know.
Not the hangar, not the pump dischare ball and retainer, the other thing above those. In the kit, and in the exploded view, there is a very small wire, I call it a spring, maybe it's some sort of retainer. There wasn't one in my carb. I'll take a picture of the new parts.
Old May 21st, 2016, 01:46 PM
  #104
That's the needle hanger.
The thing I was taking about at first.
MDchanic is offline
Old May 21st, 2016, 01:48 PM
  #105
After a quick search, here's a photo of it and the instruction on how to place it from the manual:
MDchanic is offline
Old May 21st, 2016, 01:49 PM
  #106
jharsh's Avatar
Eric, you are a good man. I am learning a few things from this post and it is almost like those Doc's that do surgery over the internet.
jharsh is offline
Old May 21st, 2016, 01:51 PM
  #107
It's a Cutlass.
These parts came in a bag with the kit.
  #108
Originally Posted by jharsh
... it is almost like those Doc's that do surgery over the internet.
I do that too:
A little to the left... A little more... Okay, now CUT!
You did make sure the anesthesia was working, right?
MDchanic is offline
Old May 21st, 2016, 01:52 PM
  #109
Needle,
Seat,
Seat Gasket,
Needle Hanger.
MDchanic is offline
Old May 21st, 2016, 01:53 PM
  #110
It's a Cutlass.
ok, so it was me, not knowing the correct terminology. Thank you so much for your patience and help here. I still don't know how mine was not there, the springy part, cuz below is what came out, unlesDSCF6112_zpse41zg6va.jpgs it flew away while I wasn't watching.
Old May 21st, 2016, 01:54 PM
  #111
Last guy didn't know what it was and left it out.
MDchanic is offline
Old May 21st, 2016, 01:59 PM
  #112
It's a Cutlass.
I need to buy you a beer! And a shot.
Seriously, if I get this done and running, it's only because of you and several other people here guiding me on e baby step at a time.
Thanks again.
Old May 21st, 2016, 02:07 PM
  #113
We try.
After all, someone's gotta help.
You're welcome.
MDchanic is offline
Old May 22nd, 2016, 08:52 AM
  #114
It's a Cutlass.
Good morning.
I'm now in the cleaning, adjusting, trying to understand all the parts before putting them back together stage. More questions of course. Maybe I'm just lucky but there seems to be no slop or play in the primary or secondary throttle shafts, even though they have not been bushed. But, in the secondary flaps, I can see light around the edges when it's closed. Having some machining background, I think it would be ok to lightly stone the flaps in the contact areas and I have started doing so making some improvement already. I am using a marker to find the high spots. I am very lightly stoning them. Before I get carried away I wanted to ask if this is a good idea or not..
Also, I may be blind but in the kit directions there is a part called an aneroid assembly and I am not seeing one in this carb. Am I crazy? Sorry if these are extremely dumb questions, I can call Cliffs if it's getting too frustrating for y'all.
Old May 22nd, 2016, 09:00 AM
  #115
Good morning.
The secondary air valves do not need to seal tightly (and SHOULD NOT). The secondary throttle plates are what need to seal, and they do. Just be sure the air valve move freely, since it is only mass air flow that opens them.
Aneroid assembly? Are you talking about the hot idle compensator that's located on the rear of the carb main body, facing the firewall?
Also, if you haven't done it, download the PDF provided way back in post no. 3 of this thread and read it.
Old May 22nd, 2016, 09:10 AM
  #116
It's a Cutlass.
yes, the throttle plates. As I read in the instructions provided by Cliff, "the secondary throttle plates MUST seal tightly in the bores to avoid a vacuum leak...."
Yes, I admit I haven't read the whole of the PDF. I will study it further.
As to the aneroid, I am only using the terminology stated in the instruction sheet. It does have parenthetically (spacer 1976) so maybe that is moot as this carb has obviously had work done to it in the past.
Thank you again sir.
Old May 22nd, 2016, 09:16 AM
  #117
If the aneroid is the idle compensator, your carb doesn't have one, so don't worry about it - there's a rectangular space on the rear surface where it could go if the carb were machined for it.
And, +1 on the throttle plates, in the throttle body, having to seal tightly - these are the lower plates, and not the flaps at the top, in the air horn, which do not seal.
I have never seen secondary throttle plates that do not seal, by the way, though their shaft may be being stopped by another part on the outside of the carb.
MDchanic is offline
Old May 22nd, 2016, 09:24 AM
  #118
It's a Cutlass.
well, as I hold the throttle body up to the light, there is absolutely some light coming through when fully closed. I was allowing them to snap closed right or wrong. It's probably in the under .010" range and some light stoning on the plates has improved that already. The plates do not close completely horizontal and I understand that would not be ideal, just trying to make it better without damaging. Thanks for verifying the acceptable lack of the idle compensator/aneroid.
Old May 22nd, 2016, 09:32 AM
  #119
It's a Cutlass.
ok, my calibrated eye is a little off. A small piece of paper is snug in the "gap" I'm talking about so probably in the .002"-.004" range, still better than it was. I simply polished the machining or casting marks on the plates.
edit: not casting marks, maybe punch press marks.
P.S. I downloaded and saved the PDF. Thank you Dalilama.
Old May 22nd, 2016, 02:50 PM
  #120
Just so we're clear on terminology, when I say "seal", I mean that the plates fit tightly to the inside of the bore. On the air valve plates, this is not the case. They come to rest against a stop when closed, but there is a noticeable gap around each when closed. Remember that these are NOT vacuum actuated, they are opened by mass airflow through the secondaries. No airflow at all, no mass to open them. Some gap is required for proper functioning.
The actual throttle blades can be adjusted in the bores. Loosen the screws holding the blades to the throttle shaft, hold the shaft all the way closed, and tighten the screws. DO NOT fully remove these screws from the throttle shaft, however. The ends are staked (so they can't back out and get sucked into the engine) and if you try to unscrew them completely without filing off the staking, you will snap the heads off.
DO NOT ask me how I know this...
Quick Reply: Quadrajet rebuild
