Won't start when cold
Old May 23rd, 2012, 07:49 PM
RickH's Avatar
'72 350 with Rochester 4BBL. Recently rebuilt. Here's the problem. It won't start after sitting overnight without pouring gas down the carb. It'll then start and run fine. It will also restart during the day. The next morning - the same thing.
I replaced the fuel filter with one that has the small valve in it. Made no difference.
The choke will set, but it doesn't sound like it's getting any gas when I crank it. If I pump it a little or a lot, it makes no difference - it won't start.
Any ideas?
RickH is offline
Old May 23rd, 2012, 07:54 PM
67cutlass67GS's Avatar
Do you see your accelerator pump giving a squirt when u pump the throttle linkage while under the hood ? Snds like a accel pump problem to me..Just my unprofessional opinion. Best of luck...
67cutlass67GS is offline
Old May 23rd, 2012, 08:49 PM
Highwayman's Avatar
First, do what Ace said. Check it first thing in the morning before poring gas into it and again after you get it running. If you don't get a shot of gas first thing but do get it afterward it might be leaky bowl plugs.
Q-jets are notorious for leaky bowl plugs and it's normal to seal them during a rebuild. If whoever rebuild it didn't know to seal them, it could be the problem. Sometimes when the carb is cleaned by soaking in a bucket of cleaner, it can start those plugs to leaking when they didn't before.
Highwayman is offline
Old May 31st, 2012, 06:59 PM
RickH's Avatar
Talking Fuel pump
Ended up being a bad fuel pump. Replaced it - runs fine
RickH is offline
stevengerard
September 10th, 2014 03:17 PM
colemane
April 13th, 2013 01:19 PM
DeltaDevil88
May 1st, 2011 10:27 AM
71supreme
November 2nd, 2010 09:10 PM
yeahbuddy
October 6th, 2010 11:07 AM
Quick Reply: Won't start when cold
