Will this ALTERNATOR fit my car 71 cutlass 350
Old Feb 14, 2013 | 07:10 AM
delta254's Avatar
Im looking to upgrade my alternater will this bolt up and will I need to make any mods.....I'm doing an upgrade stereo and electric fans the price is good...thanks
NEW CHROME I-WIRE OR 3-WIRE ALTERNATOR 110 AMP 65-85 SELF EXCITING
Click an Image to Enlarge
Product Description: Replaces Part Numbers & Specifications
OEM: Delco
Alternator Family: Delco 10SI
Voltage: 12 Volts
Amps: 110 Amps
Regulator Position: 3:00
Polarity: Negative
Alternator Family Type: 100
Output Stud Dimensions: 12-24
New or Remanufactured: New
Approximate Weight: 11.445 lbs / 5.20 kg
Old Feb 14, 2013 | 08:02 AM
It should fit.
Just make sure that you hook up all the wires, or you may have trouble with charging at low RPMs.
Old Feb 14, 2013 | 08:24 AM
Originally Posted by MDchanic
It should fit.
X2, it's a bolt-in. Since your car is already set up for three wires, there is NO REASON to use a one-wire setup, nor is it recommended.
Old Feb 14, 2013 | 08:32 AM
delta254's Avatar
Alternator
So I should get the 3 wire he has the option for 1 wire or 3 wire?
Old Feb 14, 2013 | 08:40 AM
BILL DEMMER's Avatar
Just the facts...
you're going to need to upgrade your output wiring to handle 110 amp output. and get the 3 wire version.
bill
Old Feb 14, 2013 | 09:29 AM
delta254's Avatar
bill
simple enough thanks guys
442mark
Sep 30, 2017 01:06 PM
70Cutlass_408
Aug 17, 2011 12:08 PM
yeahbuddy
Sep 19, 2010 03:42 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
