White Smoke
White Smoke
Hello:
We have a 71 olds 350 in which the heads were machined. The block is still original. My son installed the heads with new gaskets and new intake gasket. Yesterday he got it running but we have white smoke coming out the exhaust. The oil level is fine and after taking for a short ride the coolant level is also fine. Does it take some running of the engine since the heads were machined before the white smoke goes away? Anything he should look for?
If the intake gasket looks to be installed correctly and all the fluid levels are where they are supposed to be and not contaminated, then it's probably junk that got into the exhaust system and will take a good ride to burn off.
after your rebuild check all you fluids constantly untill your comfortable with the look and levels...you need to get the tranny to operating temp to get a good reading
If exhaust manifolds with pipes attached were left connected and the manifolds were unbolted from the heads, typically coolant will gush out when heads are pulled and end up in the exhaust system. On startup with everything attached loads of white smoke will begin to form when the exhaust heats up. After a short 5-10 minutes it should lessen and stop. Had this happen a few times.
It was a complete value job with new seals and valve stems. Any parts needed were replaced. valve seats, stems and guide inserts
Thanks for all your input on this it looks like the issue has cleared up. We did find that a trans line connected underneath had come off but it did not seem to be the issue. The car was driven around for at least 20 minutes or more and the white smoke has gone away.
IamaOldsGuy
October 9th, 2013 06:19 AM
