What type of valve stem seals for my 403?
Old Jul 20, 2025 | 08:08 AM
Toocool's Avatar
I need to replace the valve seals in my 78 403. Are there different type of seals? Umbrella seals, "o" ring or whatever? My engine sat for several years, now that I have put a couple hundred miles on it I'm seeing smoke when I start it. Im thinking the seals dried out while sitting.
Old Jul 20, 2025 | 10:55 AM
BillK's Avatar
If you are going to do it without removing the cylinder heads you only choice is the stock umbrella seals. Just look up whatever part number Fel Pro shows and get them.
Old Jul 21, 2025 | 10:01 AM
dieselolds81's Avatar
I used Victor reinz B45418 valve stem seals on my 5.7 diesel.They are the positive type seal with a tiny clamp around the bottom.The clamp expands when you push the seal down over the guide.
Old Jul 21, 2025 | 10:25 AM
BillK's Avatar
I might be wrong but I dont think you can put those on the stock 403 heads without machining the valve guides.
Old Jul 21, 2025 | 07:09 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Another member found a similar positive valve seal and used it on a BBO without machine work. Is the diesel guide the same diameter as the gas V8? My #6 heads had the guides turned down for SBF positive seals, I believe.
Old Jul 22, 2025 | 08:36 AM
Thanks for that.To be honest I don’t have any experience with Oldsmobile gas heads.I just figured they would probably work.
Old Jul 22, 2025 | 08:57 AM
BillK's Avatar
I did some more looking and it is kind of confusing. Some listings do show a positive type seal but it is for a guide that is .500 od which I dont think the stock Oldsmobile heads are. I think I am going to say the only way to know for sure is take a spring off and measure the guide
Old Jul 26, 2025 | 12:51 PM
Toocool's Avatar
Thanks Bill, I was hoping you would chime in here. To be honest Im more of a Chevy guy, I spend a lot of time on Team Chevelle.
Old Jul 28, 2025 | 09:51 PM
brownbomber77's Avatar
Years ago, I thought a SBF positive seal worked, .530”. I know I’ve had to cut all olds down to .500 before though.
madmax442.com
Feb 13, 2025 06:54 PM
54oldsmobile88RW
Feb 16, 2018 08:23 PM
Eightbanger
Apr 15, 2016 09:24 AM
rockettruck
Nov 5, 2012 07:28 PM
ctrain22
Aug 30, 2009 06:19 AM
