What is a stroker piston?
Old Jan 11, 2013 | 07:38 PM
Bernhard's Avatar
What makes a stroker piston?
Some venders advertize stroker pistons for the small block Olds,so is it that they are a larger than standard over bore with the olds pin size?
Old Jan 11, 2013 | 09:07 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
All the ones I have seen have had the .927" sbc pin. Remember, the stroke is achieved using 2" or Honda rod journal. The CP ones are 4.125" bore.
Old Jan 11, 2013 | 10:25 PM
Bernhard's Avatar
They use Chevy and Honda rods by the looks of it more are using the chevy rod jounal size.
Old Jan 12, 2013 | 07:01 AM
krooser's Avatar
Hot Rod Has Been
A stroker piston relocates the pin height to accommodate the longer stroke of a modified crankshaft. Without changing the pin height the piston would stick out of the bore.
Old Jan 12, 2013 | 09:33 AM
Just so we're all clear, the term "stroker piston" is a misnomer. Stroking a motor involves changing the stroke on the crankshaft, which has nothing to do with the piston directly. Changing the stroke while keeping the deck height of the block fixed requires changing either the rod length or the piston compression height (the dimension from the piston pin to the top of the piston) to keep the piston within the deck height of the block. Depending on the rod length used, you may or may not require different pistons to stroke a motor. Note that the longer stroke also pulls the piston further down in the cylinder at the bottom of the stroke, so the pistons may also require tailoring of the bottom of the skirt to clear the crank balance weights.
Old Jan 12, 2013 | 04:42 PM
Bernhard's Avatar
Thanks for the reply that helps a lot.
Bernhard
Jan 13, 2013 05:06 PM
import extermination
Oct 17, 2011 07:16 PM
442 Jack
May 23, 2008 11:16 PM
palmers65
Mar 26, 2008 07:44 AM
1972_442
Nov 25, 2007 02:51 AM
