What is my Comp ratio?
Old Apr 20, 2013 | 12:36 PM
68442's Avatar
Hi can someone shed some light on what may expect for a comp. ratio with this setup
72 350, #7 heads(64CC w W-31 Valve size), Flat top Speedpro's 30 over, .040 felpro head gaskets. No other block/head mods
THANKS
Old Apr 20, 2013 | 01:01 PM
DoubleV's Avatar
Based on the numbers you provided and assuming the pistons are sitting .010 down, about 10.6.
http://www.csgnetwork.com/compcalc.html
Old Apr 20, 2013 | 01:29 PM
68442's Avatar
The 10.5 is what the factory rated the W-31 motor in its day with steel shim gaskets(.017).
But the Felpros are .040. i was thinking in the 9.5 range with the thicker gaskets???
Old Apr 20, 2013 | 01:58 PM
DoubleV's Avatar
The numbers don't lie. You will be way higher 9.5. Your engine is also bored, so that effects it a little too.
I'm not up on the older Olds as others, so I'll let them chime in on the W-31 specifics, but understand the factory advertised 'numbers' are based on perfect blueprint specs, NOT reality. For example, the factory rated CR assumes a perfect blueprint 64 cc head and a piston to deck clearance of 0. Reality has your heads more around 68 cc's and the pistons sitting .025 down. That will make your CR alot lower than one may think.
Old Apr 20, 2013 | 02:29 PM
captjim's Avatar
I did a big write up on this back when I was at OP. YOU GOTTA MEASURE EVERYTHING! Too many variables. FWIW, every SpeePro piston I used was down .024 +/- with no decking. Again, align hone, decking, milling, gaskets, head work and rod re-sizing all affect the Cr.
Old Apr 20, 2013 | 02:50 PM
Octania's Avatar
Unless you measure your actual parts, mathematical gymnastics are just speculation. You cannot get accurate CR info from guesswork inputs, right?
Koda
Feb 23, 2015 12:29 PM
JSGD1966
Nov 12, 2008 06:36 AM
olds382
Nov 11, 2008 11:47 AM
1971olds350
Sep 24, 2008 08:33 AM
JSGD1966
Aug 27, 2008 07:46 PM
