what motor due i have
Old Nov 11, 2007 | 06:21 PM
ricardo's Avatar
I just bought a 1983 Cutlass Supreme 2door at a auction how can i find out what motor i got? i know it is a v8
Old Nov 12, 2007 | 12:55 PM
captjim's Avatar
It should have a 307. Look at the front of the engine on the drivers side, there should be a "5A" stamped on the head near the spark plug hole.
Old Nov 12, 2007 | 03:15 PM
ricardo's Avatar
thank!!!
Old Nov 13, 2007 | 11:58 AM
Redog's Avatar
Between the timing chain and the manifold you should see this number: 3161
The heads are correct, but is it has this number on the block it is a 1980-1984 307
Old Nov 14, 2007 | 08:55 PM
GoldOlds's Avatar
Didn't alot of Cutlass Supremes from '83 come with Chevy 305s? If your oil fill neck is front and centre of the engine, it's an SBO 307. Another Chev vs. Olds giveway is the distributor; if it goes through the intake manifold, it's a Chevy. If not, it's probably the aforementioned Olds 307.
- GoldOlds
Old Nov 17, 2007 | 11:08 PM
millwrightrice
Guest
Posts: n/a
I had a 79 cutlass that had a 260 in it and its a v-8 also
Octania
May 31, 2015 03:17 PM
Octania
Jan 6, 2014 09:16 PM
rustyroger
Jul 7, 2012 08:24 AM
geomen
Jun 12, 2012 03:27 PM
JCMC64
May 15, 2012 01:36 PM
