What engine?
Old Apr 17, 2012 | 01:16 AM
boeseberta's Avatar
What engine?
Hi...my 51 olds has a - I think so - late 60s engine...car was sold to me with a 350/350 combo, but I´m not so really sure what I got, at least when I pulled out the engine+auto and to find out, that I have a TH400...
I went through a lot of FAQs and threads and things like that, but there´s always something that doesnt fit, perhaps someone can help me to find out what engine I exactly have...
What I list now refers to the oldsfaq on 442.com in no special order:
oil fill tube: 9682802 (stamped)
deck height: 10.625" -> should be a BB
near the distributor hole: (big)13 87 CFO (cast)
left side of the block: 660512354 (stamped)
above the timing chain area: 395558 (big)2 (cast) -> SB
heads (driver side at the front and passenger side in the rear): 3172 (stamped)
additional infos:
-engine is painted green now, but when I removed the auto and flexplate, the engine is blue
-distributor the car came with was originally golden, stamped: 1111930 9F 16
-th400 has a riveted plate: 0A-69 19696
-no original carb, now with a edelbrock
Can anyone tell me exactly what engine I have? Maybe some kind of mixture?...What car came this engine of?...I can add some photos if needed...
Thank you,
Thomas
Old Apr 17, 2012 | 08:35 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Engine is a 350 Oldsmobile. The number next to the fill tube identifies the block . 395558-2.
The head numbers you gave, are not helpful, however.
There will be a single letter or number by the #1 spark plug hole. That is the head type. I am going to guess yours will be type 5
The 1111930 distributor is a semi-desirable part from 1969 hi-compression 350 motors.
Trans looks also to be an oldsmobile 1969 transmission.
Old Apr 17, 2012 | 02:52 PM
boeseberta's Avatar
Thanks J...that was my guess as well...and the head has a "5"...does it tell anything about the power?...as far as I know there could be 310 and 325hp on the high-compression motors...
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
