What is this?
Old Jul 23, 2022 | 07:49 AM
James71Cutlass's Avatar
What is this?
See picture below. Engine light came on. Popped the hood and it’s leaking from this black piece. See picture below.
Old Jul 23, 2022 | 07:51 AM
better picture.
it’s leaking when the car is running.
Old Jul 23, 2022 | 08:06 AM
That is the oil pressure sending unit (low pressure switch). Your setup has a mechanical gauge and a T with the sending unit (switch) for the OIL warning light in the dash.
Is it leaking around the threads? If so, remove and wrap with Teflon tape, reinstall, and see if it still leaks.
If it's leaking around the 1/8" plastic line, the brass ferrule may be loose, and slightly tightening the ferrule nut to tighten it a bit more may stop the leak.
edit:
I re-read and saw the engine light came on - do you mean the OIL light? If so, I doubt leaking threads would do that, and the switch itself may be bad and need to be replaced.
Old Jul 23, 2022 | 08:18 AM
The photos make it difficult to tell exactly were the leak is. The switch with the wire is the factory low oil pressure switch that operates the OIL idiot light. The rest of it was added by a prior owner to allow an aftermarket mechanical oil pressure gauge to be connected while retaining the OIL idiot light (that's actually a smart thing to do, by the way). The fitting for the pressure gauge tube has oil around it also, which implies that it is leaking.
Old Jul 23, 2022 | 08:31 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I always set mine up with the idiot and mechanical gauge except I hook up that sender pointing straight up and the braided oil line to the mechanical gauge. They do fail from time to time. What was your oil pressure gauge reading at the time?
Old Jul 23, 2022 | 08:55 AM
You're leaking everywhere, including the temp sender and the thermostat housing. Replace the oil light sender, clean and use thread sealant it on all the other connections.
Old Jul 24, 2022 | 06:35 AM
Thanks for all the replies. It was leaking around the black plastic piece. I bought a new one for about $15.00 and put it on. The light is no longer on and no more leaks.
herkguy
Mar 5, 2022 08:14 PM
vCode442
Nov 12, 2021 09:04 PM
sevntyW30auto
Dec 26, 2018 03:32 PM
Platinum Al
Apr 26, 2018 09:49 PM
oldsdoctor
Apr 10, 2017 07:37 AM
