Which water pump do i need? (dimensions)
As per my other thread I am putting a SBO in an 85 MC SS. I am planning on running AC with this car. Which water pump (dimensionally speaking) do i need? I am using a Stock g-body radiator too, for reference. Thanks.
side note : the car will pretty much be g-body cutlass under the hood so as far as AC config, battery config, etc, it would be as if i am swapping a 350 into a cutlass and not a monte
The G-body 307s used the 6" pump, but again that only works for you if you are using the matching brackets and pulleys.
The water pump and pulleys MUST match the accessory brackets you are using. Obviously the Chevy brackets off the Monte don't work, so you need a complete set. Your best bet would be to get the brackets from a 1980s Olds 307 and the water pump and pulleys to match. If you have earlier brackets, the pump will need to match those.
MDchanic
Tech Editor's Desk
29
Apr 22, 2025 12:22 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
MLK-442
Mar 21, 2012 11:08 AM
