w/z exhaust manifolds on small block
Old Feb 20, 2009 | 10:46 PM
smcurro's Avatar
Has anyone ever tried using the w and z big block exhaust manifolds on a SBO? I'd like to use them when I put my 350 back in my 70 cutlass. Is it possible to use them or will they not fit? I have a set of thornton reproductions w/z manifolds and I'd rather not buy another manifold set for my 350 if I don't have to.... Thanks!!
Old Feb 20, 2009 | 11:15 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
W/z 's should bolt up fine.
but if you want a set of 350 exhaust manifolds,just let me know. I'll sell you some dirt cheap.
10 bucks plus the ride.
Old Feb 21, 2009 | 05:01 AM
bccan's Avatar
They will bolt onto the head but will encounter interference @ oil filter adapter, and possibly starter. They are made for big block which has a higher deck so the angle is different.
I have often wondered if the flange that bolts to the head could be milled/ground to change the angle or whether it would make sense to have an adapter plate made that would do the same or would one of these methods even work? Would you then be fighting upper control arm/stud clearance?
I have pondered this but never seriously examined it. I looked @ the Thornton SBO manifolds hoping for the ideal compromise but they didn't quite hit the mark for me - nice thought & execution but not enough increased volume or truly independent runners. So, one of my cars has headers & the other has plain old 350 manifolds. If somebody needed to buy new manifolds, liked the design of the Thornton SBO manifold(xover flange deleted, small seperater for middle ports) and wouldn't fret over a non authentic part on their car, then they look like a good choice.
I think you should do some R & D on seeing if the W/Z can be made to fit & work without issue, maybe start w/ adapter plate to at least get an idea for angle & thickness(W/Z have enough meat to change angle enough?-doubtful) and let us know! My cars are on the road so I will never get to it but this comes up frequently & could be of benefit to many if it would work.
Old Feb 21, 2009 | 08:07 AM
smcurro's Avatar
yeah I guess I'll try to shove them in there and see what happens. Otherwise I'll either have to get a thornton set, find some on ebay, or attempt to salvage some from the junkyard. My original 350 manifolds were both broken when I took them off
Old Feb 21, 2009 | 08:29 AM
Old Feb 21, 2009 | 08:49 AM
csstrux's Avatar
Jay you got any for a big block for that price? I'll come and get them , if a truck can get close.
Old Feb 21, 2009 | 08:50 AM
yes.
Old Feb 21, 2009 | 08:51 AM
bring beer.
Old Feb 21, 2009 | 08:55 AM
I have a buddy in Rockford that is a lot closer to you though.
I can call him and ask his prices if you like.
Old Feb 21, 2009 | 09:03 AM
csstrux's Avatar
Sure, maybe set up a time when you are giong to be there, And I can come down in the car. I like guinness, what do you drink?
Old Feb 21, 2009 | 09:29 AM
No, they don't, which is why the factory never offered them, even on the W-31. About once every couple of years someone who doesn't believe this spends a couple of weeks fighting with them, only to find that they hit the motor mounts, starter, oil filter adapter, etc.
Yes, they will bolt to the SBO heads. They will NOT clear in the chassis. Olds used the extra room due to the taller BBO deck height to form the individual runners on these manifolds. The SBO doesn't have this room.
Once again, if this worked, it would have been common knowledge 20 years ago.
Old Feb 21, 2009 | 12:37 PM
Steve O's Avatar
Never tried because I always heard the W/Z don't fit on the SBO, maybe you can be a myth buster
Old Feb 21, 2009 | 03:37 PM
smcurro's Avatar
Sorry, I completely skipped over this line when I was reading. Maybe I thought it was part of your signature or maybe I'm drunk who knows. Are you willing to ship these?
Old Feb 21, 2009 | 04:43 PM
I'll be going out that way on Mar. 7th.
I drink coors regular.
Old Feb 21, 2009 | 04:44 PM
Yes, I can ship them. Just let me know if you want em and we'll set it up.
Old Feb 21, 2009 | 04:51 PM
csstrux's Avatar
I think I can make that
Old Feb 21, 2009 | 08:54 PM
4 are pending...
I have an oddball passenger side for a 70's 350 cutlass here as well, if someone just needs one.
$10 a manifold.
I should have a fresh batch coming in next month too. The junkyard is crushing everything, so hopefully, I'm going to swoop in with some more lowball offers.
You pay what I pay....I'm just trying to save some good junk.
May 30, 2012 05:47 AM
67townsedan
Aug 25, 2011 10:15 AM
citcapp
Jan 31, 2009 04:01 PM
67htc
Jul 20, 2007 07:54 AM
oldstimer
Apr 17, 2007 10:21 AM
